Thread: Cool Tech Tip
Results 1 to 20 of 23
    Cool Tech Tip
    I always like being able to add a new technique to my bag of tricks...
    This is a cool one-
    http://www.break.com/index/interesti...ir-method.html
    Toronto
    i saw them do it on the discovery channel when they were doing some arctic crossing. i think they used ether though...
    Tulsa, OK/GLOC
    I have done this with a can of Brake cleaner. Usually took us 4 or 5 tries before it would seat the bead correctly....
    Founding Member Tony's Avatar
    Ohio
    I watched a half chitfaced guy do it with oxy/accetaline after trying every type of aerosol on the shelf. It blew both sides of the bead to the outsides of the rim.
    Registered BradH's Avatar
    Atlanta/1000 Islands
    Friend of mine said they did that all the time with ether to set big tractor tires.
    He did too good of a job
    Run until it sounds expensive
    Tyson did that on my spare trailer tire last Spring with brake cleaner. Wouldnt have believed it unless I saw it.
    VP of Operations, GLOC's Fastest Pontoon 2009
    Registered dykstra's Avatar
    Washington, IL
    way cool
    on the moon . . .
    I use to work for a golf cart company when i was sixteen. Thats how we use to do it, lost a few eyebrows learning the proper technique though.
    Serious is the BOMB!
    I have done ATV tires that way
    South Jersey
    I have done it mounting 22.5s
    Registered HiZ's Avatar
    Oshkosh - Wisconsin
    Yeah> where they had the Toyota LandCruisers, all black.
    That was a sweet trek
    I'm really surprised- mostly because I'm rarely surprised. I thought I'd seen everything at least once. Maybe not.
    Toronto
    Quote Originally Posted by HiZ View Post
    that was it!
    All over da place.
    I caught that show too, but figured it only worked due to the extreme cold temps they were in. Now I know it works in the backwoods too.
    wwwActiveThunderBoats.com
    Registered dwtinc's Avatar
    Jan 2009
    LOTO
    Normal in the the trucking business years ago
    Jan 2009
    LOTO
    Quote Originally Posted by masher44 View Post
    Most brake cleaner won't burn
    Tulsa, OK/GLOC
    Quote Originally Posted by dwtinc View Post
    Napa's brake cleaner does......
    Registered jhenrie's Avatar
    Oceanport NJ
    Search tire stretching on youtube. A good time for all !!!!
    Annapolis, Md
    Used to do it mounting drag slicks all the time. Helps if the tire has soft sidewalls, like slicks, or large mudtires etc.
    Brake cleaner used to be very flammable. When they had to make it more enviro-friendly the recipe changed. Lost the flammability ( mostly a good thing) much less effective, unfortunately.
    2005 Formula 330ss
