Hello all,
A friend just picked up a 1988 30' Scarab Panther with 454ci, 385hp. Completely stock except for Gil exhaust and 850cfm carbs which seem to fat. Boat is running bravo 1's spinning Mirage 23P 3 blades at 5,000 rpms 61 on the GPS, 4 peeps n w approx 100 gallons of fuel. Any suggestions on carbs and props ? Looking for some assistence...Thanks
Results 1 to 5 of 5
08-18-2010 07:52 PM
08-18-2010 09:29 PM
08-19-2010 07:17 AM
No need to change the carbs. They can be adjusted. Send them to Nickerson or Pro Systems if you don't think you can do it. Mirages always slip a lot. Changing to Bravo 1's will make a world of difference. You'll pick up 5 mph at cruise speed. Probably even make it run faster as it will trim better. Your speed is only off by a little bit. New, that set-up ran about 67mph under ideal conditions..
Big boats rule!
08-19-2010 11:40 AM
330 hp cast iron intake 4900 rpm small heads.
08-19-2010 12:41 PM
I had one with 330's. Swapped in a pair of 420's and picked up 8 mph. It was a fast boat in back in 1986.
Big boats rule!
