I have been looking for a gas tank for the boat. I think even my 311 may need one as well. The old tanks in the boat are alluminum. I have been researching this quite a bit and it looks like the ethenol is going after welds on allum. tanks. Stainless you can only use with Deisle. Also Alum. tanks are not to be foamed in (even though every boat manuf. that I have ever run into does it). So I started to look at polymer tanks. They do make them large now. Does anyone see any down side to this?
Jon
Thread: Replacing a gas tank.
Results 1 to 8 of 8
- 907
01-23-2010 06:16 PM
01-23-2010 06:24 PM
Fund Razor just replaced the tank in his Apache this summer.
He has a thread on here somewhere detailing it.
I know he had the tank custom fabbed from some outfit that was recommended here, and he said he was very pleased with the work.
Do a search, or PM him, he might be able to help.
Bobcat also replaced a tank in his boat last spring. He'd be better for suggesting what type of beer to drink while yanking and replacing a tank."Keep the bottle on the bar Ira, I won't be long".
- 907
01-23-2010 10:58 PMThanks. The replacing is the easy part I guess the question is what is the best to replace it with. I have a couple guys around me that could build the tank, just trying to figure out if Plastic is a better solution.
Anyone else?
- 233
01-23-2010 11:27 PMhttp://www.incaproducts.com/site/default.aspx
They will do custom if the listed ones do not work. I would look nowhere else.
01-24-2010 02:03 AM
Rotor Molded tanks by ATL which now have baffles or you can build a tank using the same materials that i use to repair the tanks on Skaters .
- 907
01-24-2010 08:22 AMThanks guys. Does anyone know the cost of these compaired to a allum. tank? Does the cost go way up if you go custom or do they have somewhat easy ways to adjust their sizes.
Jon
01-24-2010 08:58 AM
You should be worried about your Donzi tank too!
- 907
01-24-2010 09:38 AMNa that thing has been mint so far. I was getting some fumes from time to time with the 311 this summer. May be a leak at the fuel pump but I can not find it. Spring will be hear soon enough and I can pull the boat and start to go through things a little better this year.
Jon
