Thread: Misc Parts
Results 1 to 12 of 12
    Misc Parts
    Have pics of everything on request...
    Thanks,
    Dave
     MEFI distributor $75, new pickup and module
     TB-IV harness $70pr
     TB-IV distributors $100pr
     (2) Fluidamprs Int 8” balancers. One looks perfect, one has a sleeve on the seal surface(?) $75 for both. Primed and ready to paint your color
     (2) HP20 TB-V modules 840130A4 (5450 rev limit) and knock sensor setups $200pr
     (2) Merc Racing oil thermostat assembly setups, complete with filter adapter and hoses for Mk IV $400pr Excellent
     (2) Mercury Racing blue HP500 alternators work perfect $90pr
     (2) Lifting eyes (head mount, mounted for pictures only) TCM TCMLFTUNIV $40 (1 set)
     (2) Rear mount Merc electrical brackets p/n 14037 $50 pr
     Crower Enduro 4.500 crank (ext balanced to 2398bw 502 ext flywheel), will include Mallory for internal balance if required) dyno time only ...PM for deatils
     oil, tranny or PS coolers. 2” x ~12” OK shape / do not leak $30 both
     (4) S pipes (cast 496HO setups) $100
     (8) 4” Merc exhaust hose connectors with clamps $70all
     (2) near new drive reservoir bottles (no brackets) $40pr
     Full set of Gaffrig II gauges for twin set up. (2) tachs, (2) speedos, (2) oil pressure, (2) water temp, (2) volt meter, (3) fuel level. All perfect and include mounting hardware $375 for all
     Merc Water pump assembly for serpentine (pulley and main hose) 454/502 MPI $40
     Merc Water pump, no leaks $25
     Isky 8005A springs and retainers less than 12 hours perfect HP500/500EFI replacements, went to bigger cam) $75
     (1 set) Dented Gibson transom mounts, can be mounted with steering ram dents down. $60
     (2) Merc HP500/Bulldog fuel pumps with fittings, work perfect $60pr
     New shift cable 865437A02 (cable only as shown) $30
     280 K-Plane plates, like new, not a scratch $200
     Merc Cool Fuel (496HO) less than 25 hours 864650 $200
     (1) 496HO intake assembly, complete with everything except TB less than 25 hours $250
     (2) Edelbrock 4150 1” carb spacers, phenolic $25 pr
     (2) 4150 sandwich style throttle mounts $30 pr
    parts
    Can you send picture of the custom elec brackets & 90 deg fittings.
    Tony @ ofboat@bellsouth.net
    Jul 2009
    Fox Lake, Il
    Can you send a picture of the (2) Merc HP500/Bulldog fuel pumps with fittings & (2) Rear mount Merc electrical brackets p/n 14037 to
    richkr12@netzero.net?
    Thanks
    Wouldn't happen to have a thermostat housing -500 HP style?
    Pics sent...
    Quote Originally Posted by merlin View Post
    Sold and removed from list...
    Thanks
    Tampa Area
    I''l take the water pump for the 454, as long it's good cond.
    Charter Member ROGUE's Avatar
    Ohio
    pick of exhaust hoses please? Are they the standard merc hoses with the dual slots on each end for the clamps?
    fluid dampers
    fluid dampers Ill take them let me know the shipping to 11804. Thanks Eric
    Hey Paradox,
    It's in good condition. PM me your email adress and I will shoot you a picture.
    Thanks,
    Dave
    Quote Originally Posted by ROGUE View Post
    Rogue,
    Sorry those were sold.
    Thanks,
    Dave
    Quote Originally Posted by 14 apache View Post
    Hi Eric,
    Guessing 20lbs it shows $29 to your zip.
    $100 to your door will work.
    PM me your info.
    Thanks,
    Dave
    Updated list...
     Crower Enduro 4.500 crank (ext balanced to 2398bw 502 ext flywheel/balancer), will include Mallory for internal balance if required) dyno time only $975
     (2) HP20 TB-V modules 840130A4 (5450 rev limit) and knock sensor setups $200 for all
     Merc Water pump (assembly) for serpentine (pulley and main hose) 454/502 MPI $40
     (1) Merc Racing Mk-IV fuel pump p/n 92864 with fittings, works perfect $30pr
     Merc Cool Fuel (496HO) less than 25 hours Merc p/n 864650 $200
