Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 60
    DJMadMatt's New Sonic Project
    Here she is. 1990 Sonic 31SS .. Much more to come soon. Just too excited and wanted to start the thread here at SeriousOffshore.com. I need to do 1 motor for it and will be taking the Long Block, which is in pieces, to the machine shop tomorrow.
    I like the look of the 31ss, that is a nice clean hull. keep us posted
    Founding Member Buoy's Avatar
    Apache Jct. AZ
    Congrats on the new ride!!! Looks very nice.
    Let's see some more pics.
    Keep us posted on progress.
    Thanks .. Gonna get some more pics after I get it cleaned up a bit. Gotta get together a "Needed" Parts list for misc stuff.
    Lake Oswego OR
    very clean and sharp
    Been awhile. Sweet looking piece.
    Does the SS have the standup head , or was that the SE?
    I know they're both nice rides......
    Hmmmm ... not sure the difference ... Mine doesnt have a Porta potty. Its a build in head.
    Now speaking of built in head ... Mine doesnt flush. There seems to be a button you push which is connected to a soloniod. Didnt work cause the fuse was blown. Put in another 30 amp fuse and it popped it as soon as I hit the button.
    Is this a bad motor on the pump? Where is this pump at and What kind of project am I looking at for this?
    Also, What kind of system is this and are there any diagrams of how it works?
    Thanks!
    Very sharp-looking boat. Congratulations!
    Quote Originally Posted by BlackJack58 View Post
    Thank You!
    See if you are able to unplug/unhook the motor, then try flushing again. If the fuse does not pop problem found.
    I'm not quite sure where the motor is though.
    show us a pic of the head.
    most have a switch that you can push up or down. Pushing UP will run both the water pump that rinses the bowl and the pump on the bottom of the toilet itself. Down will just activate the pump on the bottom of the toilet. Try another fuse and just use the Down button. IF the fuse blows again you have a problem with the toilet pump, not the rinse pump.
    you can unbolt the toilet to get to the bottom pump. when I bought my boat it did the same thing as you describe. there ended up being something jammed in the bottom pump keeping it from spinning and it would pop the fuse. I unjammed it and all worked fine.
    Here is a pic of my head. dont have a pic of the switch though.
    actually you can just about see the switch above the cabinet door on the left
    La Porte, IN The Big Pond
    very CLEAN boat!
    Contributor baddogz28's Avatar
    Feb 2009
    Austin, TX
    Sharp boat man... Congrats!
    Sell yours yet?
    Unstoppable f'n terror.
    Quote Originally Posted by HiPerf2000 View Post
    Awwww .. I see .. the pump is actually contained within the inside of the head. Thanks!
    very CLEAN boat!
    Thanks ... I'm having it all buffed out this week so It should really shine.
    Quote Originally Posted by baddogz28 View Post
    Sell yours yet?
    Thanks! Yep ... The Cobra is gone. When Jason delivered the Sonic, He hooked on to the Cobra and delivered that. Drop off and pick up. Worked great!
    Anyone know model numbers of the Port and starboard running lights? My starboard side is missing and the Port one is Chrome. I've seen the same ones on other Sonics in White which is what I'd like to get. My port one just says Attwood A-16.
