I recently upgraded my drives to all XR parts, and have some parts that need to go. I will get some pictures asap, all prices plus shipping and best offer.
Scott 216-214-2462 sklap@cox.net
1 pair early Imco Extreme upper units: 1.36(29/27)gears w/welded floors, Imco modified upper caps, Imco lower towers, w/L-15 u joints(no input yokes), no pitting on gears. Imco sets these units up with a right and left rotation. $2000.00 for the pair
2 std Bravo lower unit housings: nose cones, water holes are welded closed, clean housings but need paint, water holes can be re-drilled, I bought these with my XR uppers and never used them. $300 ea.
2 drive showers w/hoses and hardware: 1 is stamped Imco, 1 looks identical. $50 ea.
2 std Bravo lower vertical shafts: $100 ea.
1 std Bravo 1" prop shaft: .003 runout. $150
2 std Bravo 1" prop shaft carriers: w/seals $75 ea.
2 sets Bravo lower gears(non XR): 15/19, 1 set pitted on left rotation, but new on rt rotation. $100. 2nd set slight wear pattern(rt rotation) new on left rotation $150.
2 XR input u-joint yoke shafts: engine coupler to u-joint, GKN style u-joint. $125 ea.
1 Imco ext box input shaft: engine coupler to u-joint, torsional shaft, L-15 u-joint. $150
2 XR prop shaft bearing carriers: Mercury, w/seals. $275 ea.
2 sets XR lower gears: 15/19, both sets are pitted on one side and good on opposite side(5 hrs). $100 ea.
LE
Results 1 to 13 of 13
07-08-2009 07:09 AM
07-10-2009 04:08 PM
Heres the pictures. The drives are painted with black imron, but the caps need paint. I ran a Max cap and Latham steering cap.
http://s734.photobucket.com/albums/w...7-10-09015.jpg
35 Cigarette Mistress
- 37,503
07-11-2009 12:45 PMGet this with a link to the photobucket in the classifieds also.
Will get hits there too......
Let me know if you need a voucher for the free listing or listings....Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
07-12-2009 08:56 PM
Thanks..
LE
07-13-2009 04:08 PM
just blew my bravo this weekend im tearing it down this week ill be in touch once i see what i need.
07-30-2009 04:36 PM
Lowered some prices.
If anybody is interested in doing a XR prop shaft conversion, I would sell the shafts,carriers, and gears(pair) for $1200
1 pair early Imco Extreme upper units: 1.36(29/27)gears w/welded floors, Imco modified upper caps, Imco lower towers, w/L-15 u joints(no input yokes), no pitting on gears. Imco sets these units up with a right and left rotation. $1650.00 for the pair
2 std Bravo lower unit housings: nose cones, water holes are welded closed, clean housings but need paint, water holes can be re-drilled, I bought these with my XR uppers and never used them. $200 ea.
2 XR input u-joint yoke shafts: engine coupler to u-joint, GKN style u-joint. $100 ea.
2 XR prop shafts: Mercury less then .002 runout. $400 ea
2 XR prop shaft bearing carriers: Mercury, w/seals. $225 ea.
- 23
07-30-2009 07:55 PMScott, I call ya on the prop shaft conv kit
08-07-2009 02:46 AM
ttt
08-19-2009 05:59 AM
Drive showers are sold.
Waiting on payment for IMCO input shaft.
Dropping Price on uppers to $1450 for the pair.
XR shafts and carriers: $1000
LE
08-19-2009 08:38 AM
How much for all of your XR parts.
Tony @ 770 367-9053
