Question:
On ONE of my engines I have a T-fitting on the water hose that runs from my strainer to my Water pump. That hose then runs up through the "wall" where the fuel lines go through and I Have NO Idea where it goes from there. Any idea what the hell this could be to?
It is about a 3/4-1" Inner Diameter hose....
Thread: Strange water hose
Results 1 to 12 of 12
05-17-2009 03:28 PM
05-17-2009 04:08 PM
Fuel cooler to keep from vapor locking?
05-17-2009 04:39 PM
cooling system flush hose; might have had deck fitting(s) at one time. The other engine may not have the T-fitting because the hose might have been replaced in the past. my .02 - Jeff
05-17-2009 04:52 PM
Is it the AC water pickup? Do you have a transom shower?
wwwActiveThunderBoats.com
05-17-2009 05:13 PM
NO AC - Have a transom shower but it is fresh water....
05-17-2009 06:29 PM
does the hose go to the cockpit side of the bulkhead? also perhaps the flushing hose(s) may have followed the route of the fuel pickup lines then proceed forward and exit near the fuel fill hose; might there have been a couple of deck fitting near your fuel fill and fuel vent fitting?
- 37,570
05-17-2009 07:05 PMGet a helper and trace it. It has to be an old engine flush, a heater or hot water tank, or ? But you need to track it down. The BT has two, one for each engine flush, but a similar setup.
05-17-2009 11:16 PM
Pop it off and run a fish-tape through it. When you hit something, keep tapping it and listen to find the end of it.
05-18-2009 03:03 PM
i hope someone didnt get confused & run the macerator hose the wrong way.
- 407
05-18-2009 05:26 PMCould be,check and see if STECZ'S lipstick is on the other end.
