Here is another link to the BIA color codes. My books are the same.
Ebay usually has decent prices on true tinned marine wire.
http://www.brokeboats.com/biacolors.html
Thread: Full Re-Rig, where to buy??
Results 21 to 24 of 24
- 37,412
04-30-2009 11:06 PMGetting bad advice is unfortunate, taking bad advice is a Serious matter!!
- 23
05-01-2009 07:52 PMRepeated the entire length of the wire run. Hot foil stamped (no ink). On the wire material: Yes, you are right on the SAE gage. Simply design your wire circuits around your peak load requirements. Yes, tinned is better. But only if you have not properly installed your terminals and protected the termination point. Therefore, liberal use of dual wall shrink tube. Look at it this way, even the finest auto manufacturers use SAE wire under the hoods of some very expensive vehicles. They follow strict manufacture and installation procedures. Can you say QS9000?
05-01-2009 08:28 PM
why don't you buy a merc harness?
