@#$@%% my exhaust cracked and tore up my motor, am now going to take power out of my sea ray hull, rebuild motor and sell the hull, will be looking for another hull and wonder what is involved to install my bravo set up in these other applications.
Thread: trs to bravo, or alpha to bravo
Results 1 to 20 of 30
- 174
12-09-2008 04:55 PM
12-09-2008 05:02 PM
from alpha to bravo, not mutch at all, a little clearancing I believe is about it. TRS to bravo Im not so sure of, but I believe its a way different cutout, the X's are different and the adding or elimanting the trs trannies and differnt motor locations can really change the cg
12-09-2008 05:02 PM
Not sure about trs issues but if memory serves, all that is needed 2 convert an alpha 2 a bravo is 2 new holes!! Tech guys!!???
- 174
12-09-2008 05:08 PMlooked at an old trs excalibur that could be bought cheap if he keeps his power, and have seen a few sbc alpha set up that could be bought cheap, are there any x dimension issues to worry about with either set up?
12-09-2008 05:12 PM
alpha to bravo, no.. not sure of the trs i may be a bit longer
- 174
12-09-2008 05:15 PMI wondered, that thing looked awfully big, but if there is no major cutout issues, that might be an advantage... "raising the x dim with a shorter drive"
12-09-2008 05:40 PM
sbc's and alpha's/bravos are going to shave a lot of weight compared to bbc's and trs
12-09-2008 06:03 PM
Alpha to Bravo is a no-brainer, like wrink says it's just two extra holes to drill at the top. X will be the same, engine mounts will be the same. TRS is a much bigger deal and is an investment in really old stuff. If you stick with a current industry standard transom assembly you're open to options. All Bravo, alpha, volvo penta sx, and most aftermarket will bolt right in place. Good luck either way..
- 174
12-09-2008 07:34 PMyeah i have an entire bravo power package, I need to know if repowering a trs boat involves redoing he transom to cut a new hole
12-09-2008 07:38 PM
12-09-2008 07:40 PM
damn, mercman beat me..
- 174
12-09-2008 08:28 PMI did say so, read first post ha ha ha
- 174
12-09-2008 08:30 PMOh and I almost forgot, thank you guys for the help, looks like a small block with an alpha converted to my power is the way to go
12-09-2008 08:59 PM
He's still trying to draw attention away from mad max 1075 thread..
12-09-2008 09:01 PM
I answered at least half of the question as well as addressing unconsidered variables, thus my post was educational, I am sorry Mr. Stecz sir, i I have veered from my normal posting material, corrupting threads and adding color commentary. it wont happen again as my actual boating knowledge is limited to an old, underpowered resin bucket and bumming rides on opb's.
- 37,483
12-10-2008 03:49 AM
Just buy Kirk's 28 Pantera or my old 28 Pantera.
