How do you figure out if the fuel tanks on a Skater need to be redone? Is there a way to check them without an invasive procedure?
How much does it cost to redo them?
Thanks in advance.
Thread: Skater Fuel Tanks
Results 1 to 20 of 115
12-04-2009 03:12 PM
12-04-2009 03:48 PM
I would call Skater.
12-04-2009 03:51 PM
If they havent been done they most likely will for safety reasons. Its more a cause of fuel that's available these days as opposed to when it was built. Have it surveyed and inform the tech of the potential of that problem. Invasive is still the best way. I just did about a dozen core holes in a 36 Skater i have in the shop to determine the condition overall. You could have five to eight grand on up in just the tanks pretty easy. If they have leaked into the core it could get pretty ugly. I put a set of aluminum tanks in this one, problem solved.
12-04-2009 04:49 PM
get a hold of art aka offshoreginger on this site. he worked for skater and does that type of work.
toddBig Seas and Deep Vee's
12-04-2009 05:27 PM
stainless just got his done at Skater drop him a line/
It's a Skater Nation! So they tell me....
12-04-2009 05:38 PM
Glass Dave or Ginger he Worked at Skater. and here is a thread on it he is doing on another site.
http://www.performanceboats.com/html...ad.php?t=51045Slippery when wet. PODLESS TUNNEL www.cheetahcat.com ,Repairs, Modifications and Truing Cheap reliable speed.
12-04-2009 05:50 PM
I had mine done last Winter by Skater, and paid about $6k if I recall. It's a flat rate depending on the model you have, and depending on if it's already destroyed the tank. There was nothing wrong with mine going in, but since I already had it up there, I figured I'd go ahead & get it knocked out while I was having various other stuff done.
You can tell if the boat may need them done by checking the fuel in your fuel filters. If they are getting soft, the fuel will have a white material in it. My boat has always ran race fuel, which does not contain ethanol, or any other additives that could compromise the tank. If you've been running 87-89oct pump gas in the last 5 years or so, you might check them out. As it's been explained to me, 91oct & above doesn't contain ethanol?
Hope that helps a little.Last edited by GENERAL LEE; 12-04-2009 at 06:02 PM. Reason: Punctuation error
12-04-2009 05:57 PM
[QUOTE=glh;383006]I think I only have to write this another 48 times to fulfill my engagement to Jim and PBam for giving me charity in Key West....
It cuts me man.... It cuts me deep!
Oh Yeah heard Pwam gave you more then charity BIG Daddy :
now on with it B!@tch
ROCK ON !!!!!!!!!!!!!!!!!!!!
ITS A SKATER NATION !!!!!!!!!!!!!!!!!!!!!!!!!!!
12-04-2009 06:49 PM
Ohh yah sorry...
It's a Skater Nation....
12-04-2009 06:57 PM
Its in all our 93 octane around here pumps are marked plain as day 10% ,may depend on what state and how much Corn the govt has to buy from the farmerz
Back to the tanks Meister would'nt sweat the load ,if they truly need to be done SKATER can do it and when they did ours they made it look like a walk in the park ...
12-04-2009 07:17 PM
Didn't Chris w/ that Bad Azz 40 blue/silver & the 1500 Sterlings have a bunch of issues because of tank stuff?????
12-04-2009 09:07 PMThrottle-Up, Thanks for the WORLD'S FASTEST, BEST HANDLING, GUARANTEED not to break, CNC Propellers
12-04-2009 09:11 PM
it wasn't due to ethanol..... however, i will say this ------ i personally saw a 'peanut' come out of one of the filters..... seriously!!!!!
on mine, the tops/cap (or whatever it's called) wasn't sealed well on my tanks, and chris' had a similar problem. not a big deal.. easy fix...
joeThrottle-Up, Thanks for the WORLD'S FASTEST, BEST HANDLING, GUARANTEED not to break, CNC Propellers
12-04-2009 09:13 PM
gl, what nation is it again???????
