blackhawk
I am glad you get it.
The corrective action for a sagging mount is to replace them as a pair. Not lower the front of the motor. Simple, end of discussion
No one ever said to lower the front of the motor to correct sagging mounts. The topic came up to CHECK THE REAR mounts because you can lower the front of the motor and get the tool to slide in if your mounts have sagged.
Tinkerer was trying to be helpful by saying you make sure your motor is aligned AND check your rear mounts for sagging if it needs adjustment, not just adjust the motor. And for some reason a bunch of people jump on him.
I'm out.
