Results 1 to 20 of 23
    General trailer maintenance
    South Jersey
    Going over my trailer now that my boat is on the lift.Plan on doing more poker runs this year so it will be getting more use.I am pulling the rotors checking brakes and repacking or replacing bearings and seals checking all bolts and lights any thing else that needs to be done
    Good move. Its no fun fixing it on the side of the road.
    South Jersey
    Pulled a rotor tonight....When water comes out thats a bad sign going to get (4) bearing kits tomorrow
    All over da place.
    Tim, take a look at this thread and try to talk to Mark before you buy bearings, unless you can find Timken or another American manufactured bearing locally.
    http://www.offshoreonly.com/forums/g...k-holiday.html
    wwwActiveThunderBoats.com
    Check the winch strap, I had one let go. Thank God for the safety chain.
    ________
    +10000000000
    Mine broke about 4 weeks ago at 60MPH. I always use extra straps and in this case it saved my boat. I had a cable and was taking my boat in for routine service and to get my trailer checked out and the cable swapped out for a strap. Ironic.
    +10000000000
    Mine let go as I was pulling my boat out of the water. The only connection to the trailer at that moment is the winch strap and the safety chain. The strap snapped about four inches back from the hook. The boat slid back about six inches until the slack in the safety chain was taken up. Scared the chit outta me when my truck shuttered as the chain stopped the boat from landing on the ramp.
    ________
    South Jersey
    There is a Load right dealer about 15 miles from me went up there this morning and got the factory ones.I really only use my trailer a few times a year because I have a lift so its been a few years since they were done.I have to start doing it every year
    South Jersey
    Good point! I always use a ratcheting tie down from the bow hook to the trailer and two straps on the back also.
    Here's mine- off a 2007 trailer
    I heard this week that brake fluid collects moisture. And this can cause loss of effectiveness when braking. Was talking about trucks, but I wondered about trailer.
    Is it a good idea to change brake fluid occasionaly?
    Absolutely. It will collect moisture and rot your hardware from the inside. It's not terribly common, but I've seen it.
    My favorite thing to worry about on a trailer is the hitch latch. I don't care for the lever style. The screw type are commonly found on commercial light-duty trailers- I've never seen one back off. I've seen the lever style pop up- even when cross-bolted. They'll wear over the years and not securely engage. I changed the Apache to a pintle. Over 10K on a ball just doesn't work for me. Again, look at what the pro's use.
    South Jersey
    Quote Originally Posted by Bote Loco View Post
    How do you bleed the brakes on a surge system?
    Vacuum bleeder tool.
    South Jersey
    Thanks, I have one of them or two
    You'll still want to cycle it a couple times. Backing up an incline with a block behind the trailer tires works great.
    Not sure if this is a good technique or not but before embarking on my journey I always crank the trailer jack up once attached until it lifts the rear end of the pickup a tad. I figure it is a good way to make sure that it isn't popping off of the ball.
    All over da place.
    I always pay close attention to my coupler as well.
    AND I have one of these made special for my drawbar:
    http://www.trailerguardian.com/
    Quote Originally Posted by Expensive Date View Post
    I was able to cycle the actuator by hand.
    ________
    On an RV website, folks were discussing benefit of adding shocks to trailers. They said units towed smoothier as did not bounce around so much. Monroe has mounting kits also.
    Maybe tri-axle boat trailers smooth out bumps better than dual axles?
    http://www.monroeheavyduty.com/produ...rofit_kits.asp
