i thought they raised the rpm rules in SBI atleast..so i think its still considered legal..BUT NOT SHURE !
i didnt even know u can have 510 CI per SBI rulebook ???!!!!
6.8.2. Engine maintenance and rebuilds – The respective motors can be maintained and rebuilt, utilizing stock OEM parts and specifications, with a maximum cubic inch limitation of 510 cu in and a maximum compression ratio of 9.0:1, all other engine specifications and tolerances must be as per the Original Engine Manufacturer or have approval from SBIP in writing. Note: After market 502 cubic inch GM blocks may be used.
Results 21 to 40 of 72
- Jan 2011
- 677
09-04-2011 01:35 AMLast edited by 600sci; 09-04-2011 at 01:41 AM.
09-04-2011 08:42 AM
Just curious was 105 with an alluminum flywheel?
- Jan 2011
- 677
09-04-2011 11:20 AM
whats the differance ,,it ran 105 ,,that is awesome,,,i would love to be in my boat and run 100,,either way the man never claimed to be a stock 525,,so it,s all good in my book,,
ps Scott,, you have been seriously miss led about the flywheel,,a stock merc flywheel weighs 43 lbs,,that uses up a certine amount of hp ,,an aluminum weighs 12 ,,thats 30 lbs of rotating weight,,if it didn,t matter ,then why does EVERY engine builder thrive to race,, light cranks,,rods,,pistons,pins ,,ect,,? just saying,,my 2 cents,,have a great day,,IMCO #10- 2009 National Champions
- Jan 2011
- 677
09-04-2011 12:38 PMLOTO Does not have a "stock 525" class. It's a
FOR MODIFIED FACTORY ENGINES WITHOUT POWER (INCLUDES 525 SC STOCK, 500hp, 500efi, 525efi)
So it's a 525 class built up to what ever you want just no blowers, turbos, NOS.. etc.
- Jan 2011
- 677
09-04-2011 01:25 PM
if it gave just .25 a quarter of mile an hour ,,at the end of a 100 mile race ,,it would be 2.5 miles ahead of you,, stock is stock ,not is not ,,it,s like" kinda" being pregnant,,
now in svl we have 4 differant classes ,
,oss = stock 525.
.opa = rebuild and stay withen a limit
sbi = rebuild max compression 9.0 max cu.in.510. and unlimited ecu,
,and p-1 = anything goes max rpm 5800,,,
this is just a close description ,for sake of argument..
so you can see why ANY small change in any one ,is a great advantage..IMCO #10- 2009 National Champions
09-04-2011 10:29 PM
wasn't there some talk of power to weight ratio and the use of a torque meter for the svl's
- Jan 2009
- Florida
- 1,099
09-04-2011 10:43 PMThat never happen this yr in P1 maybe in the future, not sure why. That would be a question for Martin.
09-05-2011 07:36 AM
105 is fast great run!
- Oct 2009
- 307
- 37,412
- Jan 2011
- 677
- Edison NJ
- 669
09-05-2011 12:55 PMNow Im confussed again about what the class rules really mean.
I first read it as stock (do not touch the seals,ECM or any part on the Merc motor).
Then someone said it means take a stock merc motor and do anything you want to it but dont put on a blower or NOS. If this is what it means why even use the merc. name in the rules? Just say build ANY motor without blower or NOS.
Does any OFFICIAL person from LOTO staff have the answere for us or who can I call. If I miss interpreted the rules than I am man enough to give Doc an appology for racing with in the rules.
09-05-2011 02:27 PM
Im going to jump in so you guys know the rules for loto have no bearing on what the svl rule would be .
Doc didnt try to pawn off that it was a stock 525 to me and the only way that boat will go 105 in my opinion with a real 525 is on the trailer on the highway that being said this is what the rule reads that he ran under at loto.
PV2F1
p-professional
V-v-hull
2-27-31 length
F-factory modified engine ie merc 500 or 525 no power adders
1-one engine
Also the question about the aluminum flywheel it will make the engine rpm quicker at the expense of wanting to stall when you put it in gear if you have a big wheel.
Also think about it a real 525 hp verses gear size prop size and rpm pluse weight and drag air and water 105 ant going to happen i dont care what way you calculate it at least not with a real 525.Hope this helps clear things up.
Also not trying to jump into the svl topic not my place to go there just stating what i know about loto thanks gary p-f-e .racingLast edited by p-f-e; 09-05-2011 at 02:44 PM.
- 37,412
09-05-2011 03:25 PMNo problem Gary, thanks.
I can get ahold of the LOTO Shootout tech guys and find out. I think it has to be a stock 525 to fit the rules the way they currently are for the Shootout. Only the factory can modify the engine and have it still be legal. It has nothing to do with any of the racing organizations rules.Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
- 37,412
09-05-2011 03:32 PMSome of the guys are getting ahold of me and saying the 525SC, the old supercharged engine, is the only one that can fit in the class and run absolutely stock. That also makes no sense to me because of the power adder of the SC. But, I'll try to find out as I said.
If this is accurate, then you could do absolutely anything to a 525efi, and I mean anything but boost, and have it fit in the class that the Doc ran. That sounds like what he did. Everything but boost is okay maybe?Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
09-05-2011 03:51 PM
DOES IT REALLY MATTER ,? He ran 105 ,,non of the posting racers were their ,,so who,s contesting what,,,if 3 or 4 others were their and entered the same class ,,then maybe ,just maybe if you read the rules before you entered the class ,,you would have an argument,,soooo it,s moot ,,if their is a lesson here ,,,READ THE RULES BEFORE YOU RACE !!!BRING A GUN TO A GUN FIGHT,,,
- 37,412
09-06-2011 07:35 AMWell, from what I've been able to find out.......
If the engine was modified in any way, except by the factory, it would fall into the pv2m1 class, not the pv2f1 class.
The m stands for modified engines without adder's like blowers, superchargers, etc.
The f stands for factory modified engines only. So the 525efi stock would fall into f because it is a factory modified engine for performance boats/racing, if it gets modified in any way, other than by the factory, it goes into m. That was what Lance ran in last year.
I'm still waiting for official feedback on the record though...Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
- Jan 2011
- 677
09-06-2011 10:40 AMi think the rules no matter in which class and where..are very confusing and could be mad a lot easyer for everybody to understand not just in this shootout also in any spec class !
On this one tho, im with george..WHO cares..lol
Hope to see some of u in NY for the race to remember 9-11 !!!!
