Results 1 to 8 of 8
    Mooring Whips?????
    Registered jeffbare's Avatar
    Gig Harbor, WA
    Does anyone use mooring whips for thier smaller boats? I have a 20' Mastercraft I plan on keeping on the dock, and was looking at the differnt mooring whips available. I plan on purchasing whips with a 5000# capacity. There are several differnt brands, and I was wondering what experience other members have had. They will be used on salt water.
    Thanks,
    Jeff
    Gig Harbor, WA
    Anybody use whips?
    Lake Oswego OR
    afraid to answer that one........
    Everyone around me uses them. I will ask around to see what ones they are using. They definitely help and work from what I have seen.
    Jan 2010
    GTA Ontario & Georgian Bay
    I've used the "Mooring Whip" brand for the last 20 years. Have had a Donzi Hornet, a 25 Magnum Sport and a 24 Bertram at various points in time over the past 20 years all on the same original set. I am in a high traffic location and have never regretted buying them. Single suggestion: don't over tension them. Use less than the instructions tell you. I am aware of several cases that too much tension caused them to break.
    They do work quite well, as mentioned. They can splinter slightly, on the outside, as they get older. Just be careful not to run your hand down them, at that point, or your hand will be full of fiberglas splinters. Been there. Maybe a coat of brushed-on clear epoxy would take care of that problem.
    Founding Member - E Dock GENERAL LEE's Avatar
    GLOC/A1A
    I use them on my 20 Cigarette, and they work really well. My dock is located in what is probably the roughest area on the lake, where you'd still even HAVE a dock, and the whips keep the boat a safe distance from hittting anything.
    I'm interested in hearing what brands everyone recommends too, because I'd like to put another set on the other side of my dock for guests. I was pretty surprised at how pricey they can be, depending on the brand & load rating, when I was shopping for them last week.
    All over da place.
    Quote Originally Posted by OneBadInjun View Post
    Maybe covering them with a custom canvas "sock" or perhaps a noodle would be a safe bet.
    wwwActiveThunderBoats.com
