Results 1 to 15 of 15
    Adjustable Ball Mount
    Charter Member Woody's Avatar
    Ophelia/Richmond, VA
    Anyone know a source for an adjustable ball mount 14,000# +
    Thanks
    Wicked
    Registered Trim'd Up's Avatar
    STL, on the ILL side
    Are you wanting something easily adjustable that you will be adjusting often or just something to get the drop you need? What about something like this with a pintle/ball combo?
    http://www.trailerhitches.com/ball-m...ntingplate.cfm
    I would never consider it. Draw bars are cheap. Get a selection. I sure wouldn't trust the hardware or connections regardless of what they rated it.
    I did see that one. Thanks. Was trying to find one that was easily adjusted or at least had more adjustment. That only has two positions with a 4-hole pintle mount hitch. Not sure what height I'll need with the new rig.
    Wicked
    You will have to investigate further. The main piece in this kit what you may what. I have used them many times.
    http://www.hitchestogo.com/rv/weight_distributing.html
    I have seen other HD adjustable mounts just can't find them now. Good ones do exist.
    Registered danh63's Avatar
    Ohio
    I had one made it is in a thread in this section
    Here ya go.
    http://www.hitchcorner.com/ball_mounts.htm
    My buddy has one he got from here (about half way down the page) and it is rated it to 16k. It is a pintle/ball combo deal. It seems very well built, and he pulls a backhoe with it nearly every day.
    Quote Originally Posted by Woody View Post
    With every new boat, I buy a few hitches and try them out. Keep them clean and (most) stores will take them back within a certain time frame. Keep the one that works, return the ones that don't. Unless you need/want to adjust, a single unit eliminates a few potential points of failure as well.
    I'd bet someone on here will be able to give you a good starting point as well.
    Here ya go.
    Not that I'm looking but, the pintle is rated to 16K but as a ball mount its 10K 1k tongue. dont know why but its still only rated to 10k for ball mount. I wouldn't use it.
    All over da place.
    I just saw this in the new Cabela's catalog tonight:
    http://www.cabelas.com/cabelas/en/te....form23&Go.x=0
    wwwActiveThunderBoats.com
    Thanks Brian
    Wicked
    Registered Big Time's Avatar
    Stamford, CT
    Nice find. I could use something like that.
    Registered B.Z.'s Avatar
    Evergreen Park, Il
    That thing is nice..would make it easy to go from boat the sled trailer!!!!
    Registered LIVE WIRE's Avatar
    Dec 2008
    HUDSON RIVER & LI SOUND
    This only has a 10,000 rating but I think its a great idea from B&W hitches
    http://www.turnoverball.com/interface.html#/tow/ Click the TV commercial
