Looking really good Rob. You'll be in the water soon?
Thread: I have a new toy.......
Results 121 to 140 of 376
- 37,464
05-09-2013 04:10 AMGetting bad advice is unfortunate, taking bad advice is a Serious matter!!
05-09-2013 05:10 AM
shooting for june 1st
05-09-2013 07:03 AM
Ahhh... the joys of a single in a case like this.
Not trying to armchair quarterback, but did you test the exhaust manifolds?
I see that the port side seal between the manifold and the riser has leaked. Doesn't mean that it leaked in, but the old guys used to always tell me that if they leaked out, they likely leaked in. An inspection/replacement of the riser gaskets would be fairly cheap and easy.
- 37,464
05-10-2013 04:08 AMGood eye Fund, great advice.
05-10-2013 06:43 AMP-4077 "The Swamp" S.B.Y.C. and Michigan medboat mothership
05-10-2013 07:09 AM
Yeah, that is odd.
Wonder if they go under.
I found this, not sure if it will help. It was too big to attach, so here is a link to where it is hosted:
http://www.maxumownersclub.com/forum...cruiser/23.pdf
- 37,464
05-10-2013 06:50 PMSo page 6b-22 has the diagram. Nice find Fund....
05-10-2013 07:41 PM
Hey, they DO go under the manifolds.
05-10-2013 07:45 PM
Damn. I looked at the pic too long. Gonna be a long exhaust hose.
It made me want to put Gils in there that mix about 15 inches back with some chrome pipes.
Or CMIs.
05-10-2013 10:52 PM
got the shift bracket all figured out, it was pieces parts, and the throbble cable setup. found one of the coil connectors was trashed, picking up a replacement at napa tomorrow. got some electrical gremlins... think everything is hooked up, put power to the boat, bumped the key, motor will turn but nothing else seems energized in the boat. making good progress.
05-10-2013 11:16 PM
Keyed hot for ignition is the purple wire. Key on every purple should have 12 volts.
05-12-2013 11:16 AM
making more progress... got the shift plate sorted out and mounted, fabbed up a throttle cable mount, fabbed up a mount for the oil and steering coolers, they didn't fit with the offshore mount. I had to make a new mount plate and space them down and in a bit. It does help to have a welder and lathe in the garage I had to unhook an oil line briefly for access. got oil dripped on me. the good thing is the oil was in decent shape. no burnt smell, no milkeyness etc. I do have some work to do with the steering hoses. I have the old style brazil actuator and the lines are for the new style. I have another pump and cooler wth the old style lines though, just have to figure out what I need to swap out. One of the coil connector plugs got bashed in shipping and broke, have a new on coming in from napa Monday.. still on course for first test run in 2 weeks.
- 37,464
05-15-2013 04:25 AM2 weeks would be sweet for in the water......
- 37,464
05-16-2013 09:21 PM
more progress!!! pulled the rotten bolsters and spent yesterday with a table saw and a screw gun... piks later tonite. TRied for first fire. It will start on starting fluid, but that's it. I kmow nothing of fuel injection, does it take a lot of cranking to get the mechanical pump to pump enough fuel to get the system primed?? Do I need to prime something? bleed something?? Got the power to the dash sorted out and I think I have a couple bad switches etc. nothing to extraordinary.
- 37,464
05-16-2013 09:32 PMI am really surprised they have a mechanical pump on fuel injection.
Since you are switching to injection from carb, is there a return line to the fuel tank? Typically injection will build pressure that is maintained in a fuel cicuit, or circle back to the tank, at a certain pressure like 50psi. Then when the engine needs it, it is there.
I am not familiar with your system, but I'm gonna go look at Fund's Find from earlier and see if the fuel circuit is in there.Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
05-16-2013 09:36 PM
Do you have a mechanical fuel pump on the sea pump or an electric pump. The electric pump set up needs the spin on filter filled with fuel to get running. The mechanical pump will draw fuel but it is better to fill the filter to quicken the start up time.
Does the engine have a serial number you can share with me. Or a picture of the top and front of the engine and I will try to help you more.
