Laying out for cutting the access panels which is the only way to work on this.
Results 861 to 880 of 1668
04-01-2010 04:26 PMSlippery when wet. PODLESS TUNNEL www.cheetahcat.com ,Repairs, Modifications and Truing Cheap reliable speed.
04-01-2010 04:34 PMSlippery when wet. PODLESS TUNNEL www.cheetahcat.com ,Repairs, Modifications and Truing Cheap reliable speed.
04-01-2010 04:43 PM
Access Panels cut and fairing starting soon race is getting near.Damaged photo.
04-01-2010 04:45 PMSlippery when wet. PODLESS TUNNEL www.cheetahcat.com ,Repairs, Modifications and Truing Cheap reliable speed.
04-01-2010 04:53 PM
Fairing started.
04-01-2010 05:13 PM
Fairing the Bottom
04-01-2010 09:05 PM
Fairing the tunnel sides.
04-01-2010 09:17 PM
Coyote /Sonic and a name that most people have not heard much of ........or knew about , i think . Steve , at this point in your thread i am just lurking and asking questions as you go foward and to tell you the truth i am glad to see that you have so many pics to share / everybody of what all is involved from start to finish on the build of a Cheetah Cat .
04-01-2010 09:22 PM
Steve , seeing that you are in Dubi and.... being curious what type of fairing compound did you use ?
04-01-2010 09:36 PMSlippery when wet. PODLESS TUNNEL www.cheetahcat.com ,Repairs, Modifications and Truing Cheap reliable speed.
04-02-2010 09:54 AM
In 883 you can see how wide the tunnel is in this little Cat and here is a shot of the top sides getting close to longboard time and Epoxy primer, I have the Canards and linkage built, the Canopy has arrived.
04-02-2010 10:57 AM
Steve does the tunnel on this cat have any toe in or is it perfectly linear and perpendicular? Its a very unique bottom on this boat that doesnt look like anything else i have ever seen. The sponsons look to have a pretty steep deadrise with no strakes and the flat pad (?) bottom running all the way from the tip. Great stuff man, thanks!
04-02-2010 11:31 AM
04-02-2010 11:45 AM
Dave here was a good thing about that place the Acetone was costly and hard to get so I built a couple of these with parts from a hot water tank. This simple recovery system used the natural heat cycle to circulate cooling water through the condenser. In the background we were Building a Aluminum race trailer I worked out a Profile and had the Beams extruded.
04-02-2010 11:58 AM
Here is the recovered Acetone we got back 60-70% evaporation plays a large role here on the loss and the crew was taught to keep the containers covered and run two batches a day,It had a good flow.
04-02-2010 12:30 PM
Back to the Raceboat we carried everything up to the second floor including the Engines rigged and started it,Then had the roof opened and Hoisted it out with a Crane the national race was upon us by this time, we won btw Nice prizes .The photo is the canard I cut and shaped them on a table saw and covered with 8 pieces of 5.6 oz surf board cloth and 12 layers around the control shaft feathered out into the surface.
04-02-2010 12:50 PM
I flew the seats in from California, We built everything around the throttle man the driver got the wheel a compass and control stick for the canards to give him something to do.
04-02-2010 01:03 PM
Another picture, the Dash board and the white lever in front is the stick if the linkage ever failed the control surfaces would just assume a harmless neutral position in the airflow.The rear half of the fairing had the hatch on it as well with a single aircraft pull pin retaining it.
04-02-2010 01:08 PM
Is that a mastercraft seat??
