Thread: look at this...
Results 61 to 80 of 84
- 37,524
07-12-2009 09:20 AM
Jungle TG at Lake Cumberland marine stringer layout. Really it looks like just adding a stringer for the outer offshore mounts and the inner offshore mounts are modified to fit around the center stringer. And you wouldn't have the notch to contend with on the Flat Deck. If only I wasn't ballz deep in a rebuild myself....
- 37,524
- 37,524
07-12-2009 09:37 AMGetting bad advice is unfortunate, taking bad advice is a Serious matter!!
07-12-2009 11:22 AM
It would be hard to say until you actually saw the stringer layout in that Flat Deck, but it looks to me like the center stringer wouldn't need to be modified at all, the offshore mounts get cut-out a little bit and they have a little bit longer 'flange' on the outside of the mount to reach the outside stringer. The outside stringers look like they would sit between the stringer that runs under the motors and the outside offshore mount stringer in a side-by-side setup. I just think of the ease of maintenance a stagger would render over the side by side. With the transmissions its not too bad but I couldn't (don't want to) imagine trying to do anything on the backside of the motor in a twin-Bravo setup. Depending how far forward you had to move the engine room bulkhead I would think you could just have the belly-tanks cut down. Then also put some smaller saddle tanks in the engine room if need be.
Hell probably the most expensive part of it would be having the exhaust made
- 37,524
07-13-2009 07:58 AM
Couldn't make it out there this weekend. Pulled the motors out of my buddys boat Sat am and got that prepped for some stringer work. 2 cracked straingers in a 33 Powerplay. Hopefully I can get out to look at it one night this week after work.
- 37,524
- 37,524
- 37,524
07-13-2009 09:58 AMThere's just not much of a center stringer there. Most staggered race setups have a wider, offset inside stringer and that shorty center keel stringer.
07-13-2009 01:01 PM
If I were home I would go check it out (the Flat Deck), but I'm stuck down in Cincin-nasti. On second look at the pics it looks like the mufflers were shrink-wrapped so hopefully it kept out a lot of the moisture out of the motors. It would be interesting to find out what those really are.
I would think it you took apart parts-wise it would bring:
$1000 - K-planes/pumps
$4000-5000 - motors (both, $2000-2500 each)
$4500-6000 - drives/gimbles (both)
$1000 - transmissions
$500 - mufflers ?
$1500 - Trailer
$5000 - Hull
So $17.5 K roughly? He said best offer right?
07-13-2009 01:10 PMYour hull and trailer prices are fairly close. You're at about double or more on the rest. Those engines and drives- you've got to assume the worst on them. And the worst is not very good when you're talking about engines stored outside and not started for years. And those bullet-style 3's would maybe be worth 6 if they had a full refresh (which costs about that much- unless you need gears)
07-13-2009 01:13 PM
I was told the motors are Hawk 540's, but they look like 420's.
07-19-2009 10:20 PM
Anybody take a gander at the Flat Deck yet? My interest is piqued
