Prop locks?
Bobcat
Founding Member
Do they make them that you can leave on and run? or do they have to be removed? my boat sits in a highly visible area, so I need something.
I use both of the McGard products (prop and stern locks). They work great and the only time I take them off is to drain the drive oil (since I have to). Never had a problem with them, but remember to use the proper / recommended washer configuration.
John
Also ck the nut tightness after a few runs, mine has loosened before:(
Remember there easy to cut thru ,carbide bit slices thru the stainless collar, then cut into the brass nut, hammer a socket on nut and unsrew, took me less that 30min, that was going slow to not mess up the shaft:bigear:its only a deterrent,but the best we got out there.
When ya order them order some extra black caps, the fall off pretty easy
I have the Mcguards as well. Like strip said they are better than nothing, but not by much. I took one off on a buddies boat (lost key) in under 10 minutes. Drive 2 scew dirvers inbetween the collar and the nut and turn it with a crescent wrench.
Prop locks
We are runnig a sale on all McGard Prop Locks and Accessories! Give us a call and we can get you all set up!!
Prop Locks-
Mercruiser/Mercury Racing- All Bravo's (B1, X, XR), Alpha, TRS, OMC Cobra and King Cobra Drive- $51.73 kit
Mercruiser- Bravo III, B3 XR- $62.30 kit
Mercury Racing- III-VI Drives- $98.97 kit
Stern Drive Locks-
Mercruiser/Mercruy Racing- All Bravo's (B1, X, XR, B3, B3 XR) Alpha, Blackhawk, OMC Cobra, King Cobra Drives- $53.40 kit
Mercury Racing- III-VI Drives- $52.35 kit
TEAGUE CUSTOM MARINE
www.TeagueCustomMarine.com
PH-661.295.7000, FX-661.295.7007
sales@teaguecustommarine.com​
