phragle
I goy the maiden voyage under my belt. idled down the river great, temp& oil pressure great. Popped right up on plane then........ about 3~3200 rpm it cuts out hard. Push the throttle more and it flat out dies, pull the throttle back and it runs fine. It does it in neutral and under load. what do I need to check, change or fix?????
