If I remember correctly the # 7 is designed for desiels......
Results 61 to 80 of 122
08-19-2009 08:15 PMP-4077 "The Swamp" S.B.Y.C. and Michigan medboat mothership
08-19-2009 08:30 PM
How does the NXT fit into all of this?
- 3,107
08-19-2009 08:44 PMA mini #6 with a bravo as a transmission.
08-19-2009 09:23 PM
Not all speedmaster related, but what the heck.
The drive that rotated to put the gear case up in the air was the original #2 drive, turn a crank inside the boat and the whole thing spun around. I had thought the Old Man had a speedmaster lower to go on this drive, but I’m really not sure. The dog clutch shift was in the upper unit.
http://www.mercruiserparts.com/Show_...LY%2C+COMPLETE
The old OMC stringer drive had what we know as the transom assembly directly bolted to the engine, and yes there was a large rubber boot that sealed it to the boat. Power trim was an option and yes the entire engine moved on the mounts. There was a knuckle joint between the transom assembly & the drive, tilting the electric shift drive for shallow water or to trailer was accomplished by a worm/sector gear. They would come up almost 90 degrees if I remember correctly. You could run them in tilt position just above idle, any more than that was a disaster. It was fun to give your buddies a shower with it.
Volvo had the 270E drive, in fact they had a neat 6 cylinder engine to go with it. This was the standard Volvo upper with a really skinny dual drive shaft lower. Early 70’s if I have it right. I bet the torpedo was about 3” in diameter. Mercury did not have a counter rotate drive back then; at least for the small block stuff so many of the early Magnums & Cigs had the Volvos. These lowers were an instant 10 MPH or so over the stock Volvo. And ------------ they would break if you sneezed at them, never designed for a V8.
The #7 is kind of a transformers #6, same upper but a single drive shaft lower. Were not around for very long,
My Cig had the skegs cut off the #3 lowers when I bought it, would change direction any time it wanted
- Bradenton Fl.
- 98
08-20-2009 11:01 AM
E-drives from Kenny Black's 'Lil Rhino.
Jeff
- New Port Richey
- 737
08-20-2009 11:45 AMThis is where I go to decompress at work. It is about 150 feet from my office door, lots of history!
- New Port Richey
- 737
08-20-2009 11:46 AMover 300 motors!
- 37,398
08-20-2009 11:49 AMSomehow that just doesn't seem fair to the rest of us.......
- New Port Richey
- 737
- New Port Richey
- 737
08-21-2009 05:07 PM
Speaking of cut down SSM#3's...A buddy had a 98 38 Scarab with #3's that had the skegs cut off on it. They were purchased from Bob Teague who had them on the straight bottom yellow Fountain for a long time in the late 80's early 90's. Bob upgraded the boat to #6's.
Here's an interesting article in Powerboat magazine, written by Matt Trulio (who's a member here). Great article, however, as I recall there was a rebuttal letter written by Weisman where they explained Weisman really wasn't the creator of the #6. I can't find the letter, but it was printed in PBM.
o well-branded is the super-tough No. 6 dry-sump drive from Mercury Racing that people tend to forget it began its life as an innovative creation from Weismann Marine.
power_0309_a.jpgThat’s right—for those of you who are too young to know this stuff or too old to remember any of it—Mercury Racing purchased the technology from the innovative Costa Mesa, Calif., company. Mercury refined the drive and was able to produce it at a volume Weismann Marine never could, but the concept, design and prototypes were straight from the fertile minds of Pat and Chris Weismann, the brothers who own and run Weismann Marine.
The Weismann brothers come by their inventive brain matter honestly—their father, Peter Weismann, and legendary offshore racer John Connor developed the patented Kaama drive that helped propel racer Betty Cook to several offshore world championships in the 1970s and 1980s. So for the Weismanns, innovation is in the blood.
More recently, the brothers teamed up to build a unique engine-and-drive package in AVR (Advanced Vessel Research), a 39-foot Extreme formerly named Ettore. The boat was originally powered by a pair of Paul Pfaff big-blocks installed low in the boat and “in line,” meaning with their flywheels facing one another rather than staggered side-by-side. To get the power to the twin Weismann Surface Drives, they used a clever V-shape offset box.
Their goal was balancing—or canceling if you will—the effects of camshaft rotation on handling. The idea was that if the engines were installed facing one another, flywheel to flywheel, the rotation of one camshaft would counteract the rotation of the other camshaft. The boat would not pull to the right or the left as a result of engine torque, because that torque would be balanced.
“You get the automatic benefit of engine counter-rotation,” said Pat Weismann.
The project produced mixed results and the boat was eventually sold by owner Scot Conrad to Dave Kutscher. Kutscher liked the concept of facing engines, but like the Weismann brothers, he was interested in efficiency and saving weight. In essence, he gave Weismann Marine a clean sheet of paper to not just install the engines and set them up with Weismann Surface Drives, but build the engines themselves. So the Weismanns started with the LS7, 427-cubic-inch Corvette platform and marinized a pair of them. As in the original Ettore boat, the engines were installed flywheel to flywheel.
“Nobody had done a marinized LS7 that I had seen, and we were after the best horsepower-to-weight ratio,” Pat Weismann said. “We were playing with efficiencies. We wanted to see how fast the boat would run with a minimal amount of horsepower. We’ve been working on engine packages to go with our drives and gear boxes.”
To that end, the AVR stepped V-bottom was equipped with a pair of Weismann Offset FNR transmissions, Weismann six-speed semiautomatic transmissions and Weismann surface stern drives. With the twin 650-hp, 384-pound engines turning 7,500 rpm, the boat averaged 104 mph during the late-2008 kilo runs on the Salton Sea (see “Track Record,” February 2009, Page 50).
“For a long time everyone thought big horsepower was the way to go,” said Todd Petersen of Racepak Data Systems, who engineered the boat’s electronics. “We wanted to come out and show people that there’s a different way to do it. With lightweight engines, a lower center of gravity, big props spinning more slowly—efficient everything—you can do nine-tenths of what you could do with bigger power.”
For most high-performance offshore and automotive product shops, that sort of project would be more than enough for a year. But there was another Weismann product-equipped boat at the Salton Sea Speedweek, a 23-foot, six-person military vessel with a 315-hp Yanmar diesel engine. With a 44-mph top speed, it certainly wasn’t fast. But it was equipped with the latest product-in-development from Weismann, a twin-propeller counter-rotating surface drive.
The last attempt at such a drive was the Mercury Racing Blackhawk, and it failed. Setup was a challenge—no one could seem to dial it in consistently—and reliability was marginal. Mercury ended up pulling the Blackhawk from the market. But the product caught the attention and imagination of the Weismann brothers who believed that, if made reliable, a counter-rotating surface drive could work—and work well.
“The goal was trying to make a counter-rotating drive that was surfacing, because I hadn’t seen one that could take any horsepower,” Pat Weismann said. “The Blackhawk lasted about a year and went away. But it was intriguing, because counter-rotating propellers made a boat go extremely straight and eliminated handling issues—the boat doesn’t want to swap ends.
“The way the drive is designed, our counter-rotating drive has a single input through a universal joint and two sets of gears, clockwise and counterclockwise. It can be run as a single or as a twin. You can flip the rotation of the lead propeller. Because it’s counter-rotating, it kind of cancels all the ideas on inward and outward propeller rotation.”
At press time, the prototype drive, tabbed the WDP (Weismann Duo Prop), had 17 hours and Weismann said his team was “doing everything to try to break it—we only run at wide-open throttle.” To help speed up the process, the drive has giant six-blade propellers, 41"-pitch in the lead and 44"-pitch following. Weismann said development should be complete in six months, and that his goal is for the drive to be rated for engines up to 1,500 hp producing up to 1,600 foot-pounds of torque.
“I hate to put a horsepower number on it, because there’s so much more to it than that such as the weight of the boat, the propellers and so on, and people will always just push it to that number,” he said. “But that’s our goal.
“The project has no budget,” he added. “There’s no end-customer for it right now. It’s just something we wanted to do. It’s not that challenging when you start with a clean sheet of paper.”
At least for a Weismann.
– Matt Trulio is a freelance writer for Powerboat.Making the best in the industry BETTER since 1990...LIP-SHIP Performance: 305-933-9988
08-21-2009 09:14 PM
the first dry sump #6 was done for Dubia team by Wiessman's Traction Products and tested on Raggamuffin / CT Peppers in the states. WOn the worlds then demmed illegal for the following years until mercury started producing them. Thank you Pat and Chris
- 340
08-24-2009 11:34 AMIncorrect. They were completely different generation drives. The TRS and TR drives were the same uppers. The TRS was intended for Sportboats/Offshores mostly. The TR drive had a deeper gearcase to allow for up to 19" diameter propellers for larger vessels, houseboats, etc. The #1 and Mercruiser 2 drives and their corresponding transom plates, were a different design and era altogether.
- 37,398
08-24-2009 12:12 PMI'm positive the Super SpeedMaster II, was only a different foot. Everything else was the TRS.
The Super SpeedMaster I, I do not know for sure though.Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
- Where the summer never ends
- 4,346
08-24-2009 12:17 PM
