I need some help from the experts. Maybe someone has had the same problem or can give me an idea what to look for.
I have staggered 525's in my '05 -- 42 Fountain Ex. When we bought the boat both engines had bad #8 cylinders from detonation and the tops of the pistons were cooked. We had both engines rebuilt. After a short period of time we noticed a fine mist of oil on the starboard saddle tank and some oil floating on the water in the bilge. It seems to come and go and is worst when we run the boat hard at full rpms. If we run easy it doesn't seem to show up. It is directly across from the forward port engine. The mist isfrom the bilge to the bottom of the hatch and all over the saddle tank. My mechanic has gone over every connection, oil plug, distributor seal etc trying to find the leak. It has to be dropping on the driveshaft and getting slung or misting out of something. There are no obvious leaks. Any ideas what it could be?.
Thread: Oil leak
Results 1 to 20 of 31
06-22-2009 09:16 AM
- 2,001
06-22-2009 09:52 AMIs it even with the front or the rear of the engine?
- 2,001
06-22-2009 02:44 PMThere are known issues with the rear main seal on 502 blocks misting oil under a load, I think some of it has to do with the loose clearances they run for better oiling and the crank deflecting slightly.
06-22-2009 04:13 PM
Kind of had a feeling that was what the problem is. We eliminated most everything else. Hoping it was a little simpler. Any issues with it blowing out the seal and losing all oil pressure? Do you think it is something I can live with until I can pull the motor in the future? It has been going on for about a year and does not seem to be getting much worse.
06-22-2009 04:37 PMThe BBC design doesn't ventilate the crankcase very well. Bottom-end windage can cause excessive lower crankcase pressures that don't help these problems. I can't remember who makes it, but I've seen vent plates that bolt to the block in place of the fuel pump- they have an AN fitting in them that you can plumb to a tank.
- 2,001
06-22-2009 04:51 PMI know several people that have run better than 100 hours like that, it doesn't seem to get worse and does not effect the seal as far as anyione can tell.
- 1,125
06-22-2009 08:05 PMwhen the motors were rebuilt, some time the seal will wear a small groove in the crank, there are 2 different seals if I remember correctly as well, you may have one that is a c.h. too big. if the crank was scored from running lean and heat you may find the problem there.
06-23-2009 08:53 AM
Degrease and scrub the motor and bilge. Go to napa and buy a small bottle of engine oil dye and dump in, run the boat then check the bilge with a UV light in a dark room.
Ive used this method more than once to locate the source of leaks.
06-23-2009 09:20 AMYou get crankcase pressure due to windage and blowby. The vents allow this to vent out to the atmosphere. You can run them to a catch tank. Outside temp shopuldn't have anything to do with it. Typically not a problem until you get into big inches, blowers and high RPM. You may want to look at your existing ventilation to see if there are any issues or obstructions.
- Edgerock, MD
- 1,947
06-23-2009 12:50 PMI can run all day @ 4000 rpm's and the bilge will be spotless. A few good minutes above 5800 and it's a mess. Big cubic inch engines will spray a little oil out of the rear main seal when they get the snot run out of 'em.. at least mine do! They're coming up on 100 hours and they've both done it from the get go. I change the oil every 25 hours and I've never seen either engine be even 1/4 of a quart low.
It's amazing how much of a mess just a an ounce or two of oil can make!!!
06-23-2009 02:14 PM
This sounds just like my engine. Run it at 4K rpm and almost nothing. Run it hard like we did this weekend in our Topps poker run and the couple of ounces of oil make a big mess. I squirt down the bilge and engine compartment with Purple Power and spray it off to keep it clean. I feel better that only 1 engine does it. I put a quart in every couple of times out and change the oil every 25 hours or so.
06-28-2009 07:08 PM
Plug up all the crankcase openings and figure out a way to put compressed air in the crankcase. 15psi is good. Then listen for the leak and/or use soapy water solution to spray the soapy water around the area and look for bubbles. I found a pesky leak just today after having the engine out twice looking for this leak and everything looked perfect. It turns out it was a valve cover gasket that visually I have no idea why it would no seal. This was an elevated rpm thing too.
BT
- 3,107
- Edgerock, MD
- 1,947
- 37,358
07-01-2009 11:19 AMDo you have a picture of your engines for the ventilation review? My 540's on the Scorpion are terrible at it, if I run with the breathers only, I have to wipe it up a lot.
07-31-2009 01:38 PM
The leak is getting worse. When you say plug up the crankcase openings and put compressed air in, other than making sure the oil fill caps are on tight, what else do you plug? I can make a fitting to screw on to the dipstick/oil drain hose connection to add air. Is this going to work?
