Results 1 to 12 of 12
    Anyone toast a Stainless Marine manifold?
    Okay so I lost a hose off one of my Stainless Marine manifolds. It overheated bad enough to bubble the paint, blue the stainless riser, and melt the exhaust hose. So is it done? Did I burn though the aluminum portion? Weaken it? Can I just pressure test it and run it if it doesn't leak? Any experiences with this? Thanks.
    Founding Member Tony's Avatar
    Ohio
    Id give them a call, ask for Brownie.
    registered
    St. Petersburg, FL
    I bought a couple risers a few weeks ago, I was told Brownie is no longer with S.M.
    Yes, Brownie has moved on.
    You should be able to look in through the openings at the head-manifold flange and see if there's damage. The bottom end of the exhaust runner isn't jacketed anyway so they're pretty thick. If you have damage, it'll be right at the face where the exhaust stream hits and is directed upwards.
    Thanks guys, I rigged up a pressure test device I am going to try tonight and I have a new one on the way, but I would prefer to not miss this weekend if possible.
    Sorry to hear that Ted, whats happening this weekend? I may have to bum a ride from ya, still getting things ready for the Tiger.
    The good news is if that was a stainless steel header it would probably be junk. If it didn't get hot enough to melt the aluminim I would pressure test it and run it but then pull the riser off and look down inside the manifold to make sure there's no water..
    Also, pressure check the tailpipe while you're at it.
    Lot's going on, Tighlman on Saturday, Bikini contest at Vera's Sunday, choices, choices......
    Thanks, I think the tail will be okay, it didn't get hot enough to completely melt the hose at the end, but I will check it as best possible, wish I could polish out the "bronzing"
    I had a similar issue and it held up fine.
    as or the bronzing, I feel your pain bro.
    registered
    Edgerock, MD
    Don't forget the Pax River Airshow going on Saturday and Sunday!!
    I'm planning on waiting before making up my flightplan for the weekend. There hasn't been 1 day this week that the forecast has not changed..... Phucking weatherman/Holiday weekend conspiracy again!!
    Tampa Area
    Use 1 part muriatic accid(sp?) to 10 part of water and a very, very fine, steel or brass wool. Most of the bronzing should come off.
    Thanks, I got it pretty good with Meguires Metal polish.
    BTW for anyone that finds this at a later date- when I pressure tested the manifold it was useless. The welds had given up in several places and it leaked sevrely. So if you do overheat one, make sure it is thoroughly pressure checked.
