This is a very nice 30' scarab twin engine performance boat that has been completely cosmetically and mechanically rebuilt about 40 hours ago. $23,000 spent on the rebuild. The boat actually measures about 32' with the swim deck. It has a large cabin up front capable of sleeping 4 and has 2 couches on each side when you walk in.
Name:	scarab 30 OK.jpg
Both original 330HP 454 BBC engines have been bore .030" over and completely rebuilt. The heads where decked, re-cut, and rebuilt. The motors where mildly modified with mild cams, edelbrock performer intakes, and edelbrock carbs that have been tuned and jetted for optimum performance. Both Merctrans II transmissions have been completely rebuild. Both Mercruiser TRS Out drives have been completely rebuilt.
The boat has new replacement parts for both engines and drives. Including;
Trim pumps, hydraulic hoses for trim rams, gimble bearings, starters, alternators, batteries, battery selector perko switches, distributors, exhaust manifolds and risers, plugs and plug wires, throttle and shift cables, and rebuilt hydraulic rams for the large cast aluminum offshore K plane trim tabs.
The boat was just about 5 hours ago upgraded with Lavorsi 4 lever offshore controls. The throttle and shift cables were replaced with teleflex premium 33c cables.
Interior has completely new replacement captains chairs with flip out stand up seat, new upholstery everywhere, new carpet, custom smoothed and painted dash consol, custom designed gauge panel, and new carbon fiber face auto meter marine gauges with blue led lights. All the wiring under the dash has also been completely redone and all fuses were relocated from the gauge panel to a hidden fuse box. The boat also has a custom stereo with 4 Alpine amps, 11 speakers including a jl audio open air sub woofer, and 4 batteries two starting and two new separate batteries with shore power charger.
The exterior of the boat was shaved and smoothed of the front grab rails and all unnecessary items then custom painted about 7 years ago and still looks great. The original taller windshield was replaced with the shorter sport windshield from a newer boat and was tinted. The new windshield really changes the look of the boat and makes it stand out from other rebuild scarabs. The boat also has custom fabricated and built offshore metal swim deck. This boat is the definition of a cigar boat it is long, deep V hull, and fast. This boat has tons of power and will plain out in 5 seconds without using the trim tabs. The top speed with the current prop set up is about 63 in mild chop. The boat could be a 70mph boat with cupped and labbed 23p mirage props.
The Boat is 100% lake ready and in great condition. It needs nothing because everything has been replaced. All the wood stringers and runners are solid and in great shape. There is no soft wood on this boat. The boat runs excellent and handles great. It can comfortably run 55-60mph across Grand lakes heavy swells like a dream.
This boat has been stored inside for most of its life and has a full tow-able cover.
Might trade for a shop built at my house or something else but really would prefer the cash.
Call Chase
405-205-3074
http://oklahomacity.craigslist.org/boa/4864352704.html
