Results 18,421 to 18,440 of 19373
- 37,359
08-29-2023 10:48 PMIt keeps going north and mostly missing the west coast of Florida.
Hopefully it's gone for the teams towing their boats to St Pete for the race!Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
08-30-2023 05:29 AM
Mornin!
What's the ground Windspeed? All I can find is 120 MPH which I assume is at 30,000 ft.....Fear Porn.Parabellum FJ²B
- 37,359
08-30-2023 07:14 AMIt's hard to find anything with all of the hype. The only thing I've seen about Clearwater is the guy from Fox on Coranado Drive standing in knee deep water.
Tampa Airport had a highest gust of 52.93mph at 3:53am.
They always hype this stuff though, can't seem to tell the truth. You hear them call Ian a Cat 5, but it was barely, maybe, a Cat 3 as far as I can tell. A Cat 5 is a minimum average mean sustained winds for an entire minute of 157mph, a Cat 4 is 130mph to 157mph, a Cat 3 is 111 to 129. Here is the link to Ian's highest measured wind speeds:
https://baynews9.com/fl/tampa/weathe...%3A%2075%20mph
Highest measured gust was 140. Highest measured sustained was 108. That's not even a Cat 3. It's hype, but, a Cat 3 is a bad storm, the hype is not needed.Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
08-30-2023 07:58 AM
Everyone stay safe
- 37,359
08-30-2023 08:26 AM
Heidi talked to Cynthia last night. Bradenton was ok at that time. No idea what is going on today. Web cam at Anna Maria didn’t look to bad.
- Cudjoe Key FL
- 1,325
08-31-2023 05:01 AM
Thoughts on "The Turn."
Like life, the back nine is harder.
If the front nine was harder, fewer people would make it to the back.
I regularly shot under 50 on the front before I shot under 100.
(which I did again Tuesday.) 96 at a different course. The new grips are so nice. I'm hitting the **** out of my irons. My 5 iron has gained a reputation for being long and true. 210+ with enough loft to attack greens from way out. I'm teeing off with it on a lot of par 4s. Say.... 350yds. 210 plus roll out, 120-130 yard PW and a putt. Full swings. If I go long or get a lot of roll I just drop to a lob wedge on second shot. Much more reliable than attempting a 280 driver and then chipping. 9/10 of my 5 irons are in the middle of the fairway. 4/10 of my drives are in the middle of the fairway, 6/10 are fades and slices and that's with a custom fitted draw driver.
Today I am playing with my boss, a bank president and a guy from the bank who's name I don't even know. For all I know he will be chosen this morning or picked up from in front of Home Depot. I plan to call him "The Second."
If my boss plays in front of me like he normally does, I am going to hit at him. If at any point a debate breaks out between my boss and the bank president I will ask The Second if he understands our responsibilities, should they decide to duel.
08-31-2023 05:06 AM
Mornin!
I'm Hitting the Driver straight...and Slicing My irons
I'll get it figured out...Parabellum FJ²B
08-31-2023 06:12 AM
Spend an hour on a trackman and you will see it all. You are left handed though? So your slice is my hook.
My swing plane is too much out to in with my driver, which is causing too much clockwise lateral spin rate. My smash factor is perfect at 1.5. Somehow I am getting 240-260 from a 86 mph swing.
My irons are 1.5 inches longer than standard. But I still have a nice tilt. I worked a LOT on my iron swing this year. Where my weight is, how my body sequences around, keeping left arm straight in my backswing. Not throwing a sack of potatoes over my back in my backswing, left knee naturally bent to allow rotation, fully rotating during swing resulting in belly button pointing at target and weight on left foot, right foot naturally pulling up and turning left to allow rotation. Body slightly leading arms. I practiced getting into my proper backswing position hundreds of times. (And took a damn lesson.)
I am Iron Man.
Time to get my woods straight.
- 37,359
08-31-2023 07:26 AMGetting bad advice is unfortunate, taking bad advice is a Serious matter!!
08-31-2023 08:51 AM
Glad it wasn't worse.
See a few places looking worse.
Time for weekend, time for holiday
09-01-2023 06:09 AM
Mornin!
Last Night I sliced everything...I've been doing a lot of Blockwork...I'm pretty tight...Parabellum FJ²B
09-02-2023 05:57 AM
Mornin!
Rain....it's OK....I'm Working inside Today!!Parabellum FJ²B
09-02-2023 07:59 AM
Hot weather and 20 mph winds today.
09-03-2023 07:06 AM
Mornin!
Same here....Parabellum FJ²B
09-03-2023 08:44 AM
Looks to be a repeat today. I do not remember 30 days of wind. Very odd.
09-04-2023 04:59 AMParabellum FJ²B
