Who makes a good bilge pump? I had another Rule computer 2000 pump die, just 1 year old. That's my last Rule pump (pretty sad considering the company I work for owns Rule). Who makes a good reliable no-float pump?
Thanks - Greg
Thread: Bilge Pumps
Results 1 to 10 of 10
09-03-2011 01:33 PM
- 37,410
09-03-2011 06:47 PMWhat has been failing?
- Jan 2011
- 677
09-03-2011 08:25 PMsomething is wrong somewhere else, i have my rule pumps in the boat for years..and they work great !
in the abllast tank , and in the front and rear bilge..wouldnt want nothing else !
Seachoice is an other very good brand i had used before !Last edited by 600sci; 09-03-2011 at 08:32 PM.
09-03-2011 08:34 PM
The original Lovett in my 88 has never missed a beat. Its got my vote.
09-03-2011 10:30 PM
Before Irene I checked both pumps and this one didn't run, rewired it and it ran for a couple tests, checked during the storm and it wouldn't run, ran again when I checked it after the storm, then stopped again). Not the boat wiring as I bypassed it and hooked direct off the battery and one time it would run, try it again a few seconds later and it wouldn't. Finally couldn't get to run at all so I took it apart to see what died.
This is the second one to fail, this one motor died (opened pump this time to see if it was the computer, but direct power to motor and it ran slowly once, then not at all. Seems like bearings as it is stiff to turn by hand.) The other identical but older pump on the other side has run fine for several years. Erratic quality control. Prior boat had Jabsco pumps (also an ITT company) and they would die (from corrosion) about every other year too.
I haven't found anyone else yet that makes a 1500 or 2000 gph automatic pump?
-Greg
- Jan 2011
- 677
09-04-2011 09:09 AM
09-04-2011 06:45 PM
If I have to go back to a pump with a separate water sensor what is a good non-float switch sensor?
09-04-2011 07:13 PM
I read the manual for the waterwitch conductivity sensor switch and it says it won't work well with rain water, which is what I need the bilge pumps for most, so that is a no-go. I presume all the other conductivity sensor switches will have the same limitation?
- Jan 2011
- 677
09-04-2011 07:39 PMi got a good one here, gonna check what brand it is ..maybe i even sell it !
