Results 1 to 20 of 24
    The verdict is in
    Founding Member BY U BOY's Avatar
    Houston
    finally pulled my chit box apart today Confirmed what I thought.But was not expecting this much carnage..
    I now have a custom 2 piece crank Several twizzlers that once were connecting rods some new paper weights from SRP and enough metal im my pan to get a 2 dolla bill..
    So looks like I may be getting bigger pistons better rods,stroke it out and hell why not a new cam.. Other than that all looks good.
    SOS NINJA dancing on the boundaries of hell.
    Registered Boatfreak's Avatar
    Martinsville, In
    Sorry about the carnage but I like your spirit.
    Houston
    Quote Originally Posted by Boatfreak View Post
    The way I look at it is what else can you do? Damage is done why not have sme fun with it
    Lake Oswego OR
    some very expensive looking garbage...
    Registered dykstra's Avatar
    Washington, IL
    Good luck with your new project.
    Registered endeavor1's Avatar
    Jul 2009
    LOTO
    Wow, nice job! Interesting conversation pieces now!
    Registered TxHawk's Avatar
    Feb 2009
    Texas
    Nice job. Those paper weights look like speed pro's not SRP.
    Registered Donskihp's Avatar
    Mar 2010
    VA.
    Loosing and engine always sucks! Hows the block? any damage? When rebuilding an engine it always pays off to get the good stuff.
    Houston
    Quote Originally Posted by TxHawk View Post
    you are right they are. Builder said he was going to use SRP but went with the speed pro instead was in the back of my mind.
    Mar 2010
    VA.
    Isn't that a seal Power emblem on the side of that piston?
    Houston
    cant decide what I want to do with the engine. rebiuld stock or stroke it. Guess I have all winter to decide not going to rush into it and not use it
    Houston
    one in same.
    Nov 2009
    houston,TX / jackson,MS
    Stroke that baby!
    Houston
    Quote Originally Posted by publius View Post
    Stroke that baby!
    my whole thought is for the price to stroke it I could by a 502 short block put my ZZ502 heads,intake and all the other chit and go boating. The other part of me is thinking this will make winter more fun.
    Houston
    Block looks fine,bores are clean. I think it just needs a little machine work. As always won't know until I have it tanked and sonic checked. Either way I am going to keep this block as a project if I do decide to go the 502 route.
    Houston
    Ok so lets make this fun.
    What parts(combo) would you do.
    I am going to keep the same heads(ZZ502 Aluminum)and the BG 830 carb.Everything else can be changed.
    So lets hear it but lets not get crazy as I do have to keep some sort of budget
    Feb 2009
    Texas
    Are those oval port heads?
    Houston
    yes large oval port 110cc chamber
    Mar 2010
    VA.
    The short block is the easy way, I've seen too many remans,& short blocks that are thrown together and end up out of speck. I once purchased a brand new 454 long block, still had the tonawanda factory tag hanging on it. Pulled it down to balance and blue print and was amased at how far out of spec it was.
    Jul 2009
    LOTO
    I guess eagle eyes are not as strong as hawk eyes huh??
