Im replacing the Gimbal bearing and bellows....Is the bellows cement required to be on either end of the U joint bellows? I know has to be on the Gimbal end but not sure about the opposite end (bellhousing)
Thread: Installing U joint bellows
Results 1 to 7 of 7
02-22-2010 02:59 AM
02-22-2010 08:57 AM
On bravo's the aft side of the bellows does not get glued on.
02-22-2010 09:43 AM
what he said !!!
02-22-2010 11:17 AM
ok cool
btw, the bellows was only a few weeks old when I took off the drive to find it full of water.
The bellows still looks brand new so I`m trying to figure out how water got in there.
Brian, God rest his soul, didn`t seem to use any cement on the front(came off really easy) could that be why water got in there??
i`d hate to put it all back together and have the same issueLast edited by ICDEDPPL; 02-22-2010 at 11:35 AM.
02-22-2010 11:44 PM
have to see where its coming from,,,,how did the orings look?
03-02-2010 10:28 AM
O rings on the drive? they look fine.
I tried pulling the bearing but without the right tools and a torn up knee I can`t bend it`s a real ***** working on it.. it`ll have to wait.
thank you
03-02-2010 11:32 AM
the mating surface "O" rings between the drive and transom
