Dropped an exhaust valve seat out of the head in the number 7 cylinder last time out. Had a head gasket leak earlier in the year in the same cylinder, we fixed that but I'm assuming the leaky head-gasket was the precursor to the valve seat falling out. The head cracked between the valve seats, I'm assuming this head is junk? Not to mention the valve seat pieces beating the chit out ot it...
Results 1 to 16 of 16
Hybrid View
11-11-2009 10:08 PM
11-11-2009 10:41 PM
I have a picture of my #7 cyl. on my 99 Powerquest, lost the valve seat and took out my piston, 4 days before our Boyne Thunder Poker Run 2008. I now have a new engine on the starboard side. When I find the pic I'll post it.
- Oct 2009
- 40
11-12-2009 08:47 AM
HP500 Carb. Square port, 088 casting.
11-12-2009 09:00 AM
Found the picture of my sick 454
11-12-2009 09:11 AM
Damn near anything can be fixed, but why bother? Those heads are easy to find and are pretty cheap. If it was out of a numbers matching L-88 67 vette I would say take it to the machine shop but not a boat.
- 3,107
11-12-2009 10:42 AMcast steel head, throw it out... they're cheap!
At least it didn't get the block!
11-12-2009 12:40 PM
I've been around motors all my life, the valve seat dropping out was odd. Then again most of the engines I've been around were Ford engines. Not that we have not had problems, I just have not seen this before.
- Oct 2009
- 40
11-12-2009 05:43 PM
I can put new ones in for you we have the tools
11-13-2009 07:45 AM
If you need a piston let me know, I have a view spares that I can sell.
LE
- Downtown Ruby, MI
- 213
11-13-2009 09:52 AM
I dropped a valve seat in mine a couple years ago. Gen VI 502MPI, #8. LWP got plugged and the motor got hot, next time out dropped the seat. Mine also cracked between the seats. Now it's 509" with SRP pistons and Brodix heads.
11-13-2009 02:46 PM
"088 head cracked between the valve seats and dropped the seat" Been there done that.
