Results 1 to 20 of 24
    Barrier Coating The Bottom of The Boat
    Toronto
    Looks like were having it done to try and keep the blisters away. We were told that it is a smooth epoxy that is applied and is good for 5 years. Anybody have any pictures of what the stuff looks like (googled and didn't find much)? Is it going to be clear or white? Will it make the boat slower? Pretty much, is it going to look like chit?
    Thanx guys!
    I barrier coated a bunch of boats but it was years ago and the stuff may have changed.... The Interlux 3000 we used was white and it was rolled on.... You could have it sprayed but we never did because it would be bottom painted over anyway. Even though it was rolled it would sorta self-level.
    Registered jhenrie's Avatar
    Oceanport NJ
    The barrier coat under my bottom paint looks yellowish like a resin that was brushed on. I can see it where the ablative bottom paint has come off. They did 3 coatings on my bottom. the barrier coat , a signal coat that lets me know when to re-coat the ablative anti fouling paint the the anti fouling paint.
    Toronto
    Quote Originally Posted by jhenrie View Post
    so you think its safe to assume its not going to match the white gel coat? can i still acid wash the bottom with the barrier coat?
    Interlux barrier coat is grey in color will last indefinately and when coated with VC 17 teflon bottom coat .(comes in colors now),you will never have to acid wash your hull again and will NOT SLOW YOU DOWN -Great stuff!!!!
    Serious is the BOMB!
    Josh, just rhino line the damn thing and be done with it
    Registered Hilltop Kyle's Avatar
    Feb 2009
    Somerset, KY
    We put some of the Interlux on a Baja and from 10' away you couldn't tell it was bottom painted. Up close you could see a little texture. They say if you put on a couple extra coats you can wet sand and buff it and then you'll never see it. It's good stuff!!
    I always looked at the speed thing like this. Yes it will slow you down a tiny bit, but not hardly as much as a boat that has soaked up water and has growth all over the bottom of it. Even a little bit of growth witll slow you down more then the paint. IMO if you leave the boat in the water long term even in fresh water you should do it.
    Registered Ryan8886's Avatar
    Waterford, MI
    Quote Originally Posted by Audiofn View Post
    .....or buy an Airdock. A bit more on the upfront costs...but works great.
    www.airdock.com
    Registered 38fountainSC's Avatar
    Akron, Ohio
    Our fountain sat in the water all summer with no bottom paint. By the end of the summer we lost 5 mph. It cleaned up nice with muratic acid and no signs of blistering but I think I will bottom paint next year to try and stop the soaking and slowing down effect.
    Quote Originally Posted by 38fountainSC View Post
    Remember this. Bottom paint is not a water barrier coat, only water barrier coats will stop soaking. As far as bottom paints go they all soak water up like a sponge and ad hull wieght except for VC17 by Interlux. just do not want you to make a bad mistake.
    VC17 by interlux will not slow you down but should actually speed you up. I've personal experience with this product on several boats in West Michigan.
    Quote Originally Posted by Hilltop Kyle View Post
    Your correct, just want to add wet sand only with old sand paper, you want to burnish the metal in the teflon to make it perfectly smooth, new paper will cut not burnish. I prefer to use a beveled edge bronze block to burnish VC17.
    Quote Originally Posted by FASTERDAD View Post
    I have not done it myself, but I have heard of rubbing vc17 with newspaper to burnish it....
    I agree and hull's blister easier in fresh than salt.
    Traverse City, Mi
    I've had the Interlux white epoxy bottom coat on my fountain for 6-7 years.
    I acid wash it once a year and frequently wipe it down with black streak remover also after each use to remove the waterline crud. It has held up perfectly.
    The color is slightly to the grey side as compared to the original hull gel. Mine was rolled on and tipped with a brush and although it isn't prefectly smooth like gel but I'll take it over any alternative.
    ed
    I agree Fresh water is less dense and can seep through easier.
    I've heard that too,haven't tried it but the Teflon is soooo thin that it doesn't take muchto burnish, I'll give it a try next spring-thanks
