Results 1 to 5 of 5
    Miss GEICO offers free seatbelt cutters to all race teams
    Charter Member / Competitor
    Jupiter, FL
    That's cool Scotty.
    For those of you not familiar with these, we use to use a similar device when I raced cars way back... But the new one Scotty with the Geico team is offering is one which was designed for cars, and small enough to not be in the way in any application.
    I like that they will all be in the Geico Yellow color....
    Res-Q-Me Rescue Tool
    The new RES-Q-ME from Task Force Tips is a small versatile tool that can save your life! This ingenious device is intended to be placed with your car keys. It contains a spring loaded tool steel pin that will break any tempered glass window and a stainless steel blade for cutting seatbelts. The break apart design allows the RES-Q-ME to be quickly removed from its storage location without removing the keys from the ignition. The RES-Q-ME is easily carried on a key ring or can be attached to different places in your vehicle.
    Blade Guard: Remove to use.
    Seat Belt Cutter: Hook over seat belt and pull.
    Window Breaker: Push this end of the tool against the window until the concealed spring loaded spike releases and shatters window. The spike is self-resetting and may be used many times. About 12 lbs (5kg) force needed.
Name:	resqme botach.gif
ID:	72847Click image for larger version.
    Registered rschap1's Avatar
    murray lake lowell mi
    AWESOME gesture !
    FAR exceeds that of filing a lawsuit.
    Way to be part of the solution, NOT the problem
    i about fell down when i heard that anyone would ever strap themselves into a boat without one.
    Too many of us forget that sometimes stuff doesn't always work like it's supposed to and has the last 999 times.....
