Dont feel bad John, my Cigarette Hatch leaks on the driver's side!!! it must be karma!! come to think of it every boat I have had has had a leaky hatch!!!
Thread: Funds Brave restore thread
Results 141 to 160 of 840
05-03-2009 07:46 PM
05-03-2009 07:54 PM
We call that starboard, Bill.
I am tossing the bilge pumps and float switches too. Too much milkshake for too long. They have it all inside.
Just take the Cig to a real marine joint and have them fix the hatch. Just don't take it to the corvette guys unless you only need paint.
Hoping to get parts very soon. Ordered rotating assemblies first week of March and I am still waiting.
05-03-2009 08:38 PM
I've yet to encounter a boat that didn't have a deck hatch leak.
Does such an animal exist?"Keep the bottle on the bar Ira, I won't be long".
05-03-2009 09:40 PM
I guess if there is a little mold left, it takes off. It was a florida boat, after all.
That is the pic from the suirvey, I believe.
So, two owners ago. Perhaps a pic from late 2007.
The cabin is actually kind of a yellow, with red and black mold. Anything plastic has the red mold, anything vinyl has the black.
I may be able to save the headliner. Hopefully a bleach solution will kill the fuzz in all the hull lockers, so I can paint them to try to stop it.
I need to figure out a gasket of some kind for the anchor locker. Water gets in there and it has trouble getting out.
05-03-2009 09:44 PM
wheres the pik?
05-03-2009 10:07 PM
It is in the bow Tracy.
05-03-2009 10:12 PM
Speaking of lil things to do.... the boat has two lights. One transom light and one 360 degree white 2nm mast light on the deck forward of the cabin.
There is a wire to the bow. Should I do a bow combo light or should I do a red light midships port and a green light midships starboard? The combo light would be easier, if the wire is good. If it is bad (it's glassed in) it would be easier to do side mounted.
I need to change the mast light out for one that has forward light for running and 360 nfor mooring.
05-03-2009 10:14 PM
you are making me feel bad John!! here is a pic after is was cleaned!! it cant be that bad!! did you put moisture control bag and cans in her over the winter?? why do you need a cabin!! get her running!!
05-03-2009 10:19 PM
Don't feel bad Bill. I did a bag, and had it in a dry place, but I think that the bad hatch may have given it just enough moisture that it sprouted, then sort of laid dormant over the winter. But the bag filled up and that was that. I parked it from October to April.
It is nothing to feel bad about Bill. I knew that the potential was there when I put it away. A little mold left over can take off.
Heck.... the power amp has mold on it.
05-04-2009 08:43 AM
John we had some yellowing on our interior that cleaned up really well last year, but I worked hard to get it that way.
I used diluted Purple Power and a Magic Eraser as my main source of cleaning products. I wipped down the area first, left it wet, then used the ME and PP, scrubbed well, then took a clean water rag and rinsed that area. It came out well. We were able to get the yellow out of ours.
Make sure you use bleach and water on the mold, otherwise you have the potential for it to come back, plus it will help take the stale smell out of the boat.Queen of Bammin'
05-04-2009 09:05 AM
I am right there with you with the bleach. I started in the anchor locker, and I will work my way back in every locker, then I will start at the bow again and hit it again for good measure. Then I will paint the lockers when dry and clean with some Petit. With all of that and the new hatch, I should be ok. But the actual cushions may be too far gone. We will see. They were so "alive" that the zipper pulls disintegrated and became one with the seat base underneath.
I will get rid of it all. The boat sits in the sun and I can leave it open whenever it is low humidity out.
05-04-2009 09:11 AM
get a dehumidifier and stick it in there... would a prime base of killz help in the lockers?
05-05-2009 06:28 AM
I have a bag that I can "re-charge" I thought about killz, but am thinking that if I kill the mold first and get as much of it phyicially off the boat, some petit would make a nice barrier coat. (and look nice)
1988 sure was a great year for access hatches to empty spaces.
05-05-2009 08:13 AMKilz is pigmented shellac with an anti-microbial chemical in it. It will keep drywall that's got bacteria in it from staining through new latex paint. But it won't hold up in a boat.
