BAMM!
Mornin!
Van just sheared off two Bolts off of the new Starter Motor....Might need a new Flywheel...
Now that's an awful sound.
Results 15,401 to 15,420 of 19499
05-09-2021 07:01 AMParabellum FJ²B
05-09-2021 07:15 AM
Classic symptom of reversion.
05-09-2021 09:09 AM
Happy Mother’s Day
05-09-2021 10:17 AM
I'm an Orphan...
Might be Compressed Water...Some liquid came out of the CC when I jacked it up...Parabellum FJ²B
05-09-2021 11:37 AM
It's Official...Cylinder #5 is a Water Fountain, and the Starter didn't break the Bolts...it broke the Block...Getting quotes on used and Reman's..
It's either dump a Thou into this, or into the E-250...
I can buy a slightly Tuned Reman Long Block for $1250 , or a Used Fully Dressed for $750 delivered no Core Fee.
Decisions, decisions .Parabellum FJ²B
05-09-2021 02:53 PM
What size engine?
05-09-2021 04:04 PM
4.3 Vortec
05-09-2021 07:07 PM
Those were pretty good engines. A used engine should be ok?
05-10-2021 05:05 AM
Mornin!
I'm getting quotes from all over..I wonder if this is too good to be true?
https://spprecision.com/products/43-...gine-sale.htmlParabellum FJ²B
05-10-2021 07:04 AM
Are you attempting this yourself? Do you have a equipment rental place that has a cherry picker?
05-10-2021 09:33 AM
Sounds like work no matter how it happens.
Good luck with it.
- Cudjoe Key FL
- 1,378
05-10-2021 06:36 PM
Damn. I hoped it wasn't water. But there was almost nothing else it could be.
I have invested a considerable number of flywheels and starters into my education on this.
05-11-2021 05:54 AM
Mornin!
The Water has been the problem all along...Multiple Misfires on #5.
I've got the Machines , remember I used the Lull to pop the Powerhead off of the 200 Merc.
Driving the Dump Truck....$24 a Day in Gas....Parabellum FJ²B
05-11-2021 07:12 AM
Back in the early 80’s as service manager we would dump water down old ladies carbs. Carbon would build up on top of the pistons, Bud would go get a coke bottle, fill it up with water, then rev up the old ladies car and run water thru the carb. It cleaned the carbon off the top of the pistons and the knock would go away for 6 months.
05-11-2021 07:24 AM
Two important things Bud did: Let it get hot first, let the rotating assembly get a running start.
05-11-2021 09:35 AM
Heard of drawing Sea Foam down the PVC to help clean up and loosen carbon before replacing plugs in the 5.4 fords...
05-12-2021 05:03 AM
Mornin!
Bring back Leaded Gas!!!!!Parabellum FJ²B
05-12-2021 05:42 AMParabellum FJ²B
