When Im chillin running the stereo, I can switch to the deep cycle, then switch back over to the starting batt when Im ready to go...
Results 101 to 120 of 267
05-26-2014 05:39 PMP-4077 "The Swamp" S.B.Y.C. and Michigan medboat mothership
- 37,866
- 45
05-27-2014 11:04 PMJust don't forget, (like I've been known to do).
If all of your grounds are solid, and it sounds like they are. You should get home every time!Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
05-28-2014 06:53 AM
Are you saying that if they are solid, they are stranded?
05-28-2014 08:06 PM
A;; mire wire is stranded so it should be solid.
Got one side panel inm courtesy lights wired and speakers installed. Will do the other side saturday and finish up some odds and ends in the bilge. getting a lot closer....P-4077 "The Swamp" S.B.Y.C. and Michigan medboat mothership
- 37,866
- 45
05-28-2014 11:13 PMI mean solid as in well grounded. Grounds in boats always seem to be the number one area of issues and he has his buss blocks separately grounded back to the battery grounds. Stranded wire is always best.
05-31-2014 08:17 PM
A little progress....
06-01-2014 07:26 AM
Looks good.
06-01-2014 05:21 PM
Threw power to the system today, nothing smoked!! chartplotter works, courtesy lights work, bilge pump, bilge lights,elec.compass, blower all check and the stereo . Water test 2 weeks.
- 37,866
- 45
06-02-2014 06:34 PMInterior is looking very sweet.
- 37,866
- 45
06-10-2014 10:58 PM
Busy day today... Got the console mounted, throttle/****er mounted, last to cup holders wired and mounted, couple step plates mounted, head up trim indicators mounted under the dash, neutral safety switch wired up, sent the seat bases out to be modified ( upon drilling the access port to thru bolt the seat I found that the inside bolt holes would be to close to the stringers, so I am having a 3" strip of stainless welded in to move the mounting holes), fabbed the cable mounts for the tab cylinders and whipped up some stainless brackets to mount the cable ends to the tabs. Also ordered a shift cable adjustment tool and my 5 watt handheld vhf showed up today.
06-11-2014 06:54 PM
Got my butt kicked by a 1/4 hole today. Fabbed up the tab mounts for the mech., indicators. First 3 holes in the stainless tabs took 45 minutes, the last hole took me 3 hours. gonna get the correct size bolts etc saturday.
06-14-2014 10:47 PM
Just a couple loose ends to tie up in the morning, then a good wash and wax and its boat ride time. Couple piks to summarize the project
Before, during and after...P-4077 "The Swamp" S.B.Y.C. and Michigan medboat mothership
06-14-2014 11:04 PM
You rock. I was gonna call you today but got busy.
Are you running her tomorrow?
06-14-2014 11:17 PM
Not unless I can find a 5/8- 20 nut. Somewhere along the rebuild and shop move I lost the nut for the steering wheel. Tried menards, home depot and lowes, any ideas??
06-14-2014 11:37 PM
Yeah, that's a pretty fine thread for 5/8.
Fleeger's would have probably had one. But they went out of business.
Maybe Ondrus, but they are closed Sundays.
This is when I miss real hardware stores.
- 37,866
- 45
06-14-2014 11:47 PMSee if you can find a tap at one of the hardware stores or sears or ?, and if so, buy a bit smaller nut, ream and tap it.
06-15-2014 07:27 AM
Two pairs of vice grips on the column....and Wallah!!!!! Custom steering wheel !!!
- 37,866
- 45
06-15-2014 09:10 AMAre you positive it's not a 5/8 18?
