Results 9,641 to 9,660 of 19491
03-22-2017 10:06 PM
Last edited by Ratickle; 03-22-2017 at 11:34 PM. Reason: Fixing the Dink's lack of BAMM
03-23-2017 07:52 AM
Mornin Ho's !
He's missing a lot more than thatParabellum FJ²B
03-23-2017 02:53 PM
Frosted Flakes. Sounds like liberals right about now.
03-23-2017 03:06 PM
Sounds like He's hitting on Me
03-23-2017 10:58 PM
Crane 13532-16 Yay or nay???
03-24-2017 07:47 AM
Mornin Ho's !
- 37,497
03-24-2017 08:28 AMMorning Ho's!!
Crane makes a pretty good lifter. You have to make sure you have the correct length pushrod though with that one. And are you going big lift to have to use that? If so, watch your overlap closely for possible reversion issues.
Probably overkill for the rpm you are going to run, (I'm assuming). But, overkill keeps things running well longer!!
Who's your engine builder?Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
03-24-2017 11:10 AM
Happy Friday
03-24-2017 07:10 PM
.610 max lift. its the 731 cam with stainless marines so shouldn't have any reversion issues. looking to spin about 54-5500 rpm. Its just enough lift to get iffy with the factory dogbones... Engine builder is.... Gressman is dong the bottom end and lightening Jet (john) is helping me put the top end together. then we will dyno at Gressmans...
REcipe as evolving is a gen 6 forged 454 8.5:1, 731 cam, AK racing alum heads bowl work on intake bowl and port work on exhaust, (they flow better than AFR 320's) Inconel valves, powdered metal seats etc.. 177 blower @ 5 pounds boost and a Bill Mitchell modded 1050 dominator. should be a little over 600 hp.....P-4077 "The Swamp" S.B.Y.C. and Michigan medboat mothership
03-24-2017 07:16 PM
We are also raising the X 2 inches..... My best speed is 62 gps... any guesses with double the hp and the raised X ??
03-25-2017 06:05 AM
I'd be surprised if you don't at least see 65.
03-25-2017 07:53 AM
Mornin Ho's !
83.4 MPHParabellum FJ²B
- 37,497
03-26-2017 08:38 AM
Mornin Ho's !
03-27-2017 08:18 AMParabellum FJ²B
