I will look later. It must be of St Clair. Yes, you have to lift there.. most everyplace else we race it is not necessary.
I think it was you Dean that said earlier after the first turn you do not need to hug the buoys. You can make the turn wider so you don't have to lift.. I have found it faster around the turn to sweep it if you can.... Sometimes there is some one in the way or faster boats overtaking you and you are forced to turn harder then ideal. But oh. well that is part of it. You just have to learn to make the best of each and every situation.
Thread: Tips for a Rookie on Turning
Results 41 to 60 of 70
- Lake Travis Texas
- 6,844
05-18-2010 01:24 PM
- Lake Travis Texas
- 6,844
05-18-2010 02:07 PMWell then, That explains that.
I wish all our races were in the Ocean. There are a whole set of different skills needed there.
- Worldwide
- 15,485
05-18-2010 02:39 PMthe lines the cat OB took 1st turn in St Clair
svl at the first turn, now picture a few more in the mix
- Dec 2008
- Lake of the Ozarks
- 212
05-18-2010 05:26 PMDean's got this one, Some of you all need to refigure the math on "sweeping" turns. There is a short way around and a long way around, and you would be surprised the amount of extra speed you need to carry to go only two boat widths further in a arc around a two pin turn. Regardless. SVL guys go back and look at your LOTO laps last year, We were watching on the turn just past start finish. Sweeping, Arcing, Chopping, whatever there is absolutely no reason not to be inches off the first pin.
- Dec 2008
- 212
05-18-2010 05:35 PMDaredevil, That idea you had teaming up actually sounded good for a split second. But I'm pretty certain it wouldn't pan out. Plus if your keeping that thing in Class 4 OPA, I don't believe your boat has a chance against the Simmonsnator. I also couldn't be associated with your B.S. I did just see however a video you have on youtube for sponsorship, couldn't watch it for some reason, this computer is not working right, but good idea putting it out there. Would still love to race you some day though. Keep taking pointers from everyone on here for driving skills, it is making my chances better and better.
- Lake Travis Texas
- 6,844
05-18-2010 05:44 PMWell you didn't see us lift on that end. As it worked out the apex hugged the second pin and the third was tight. turning on the first pin as you say only forced an adjustment of the turn for or at the second pin and /or left you wide on the third.
I must have done it right because we made ground on the black boat every turn. They were actually a little faster on the straights.
You have your way, I have a different way
- Where the summer never ends
- 4,346
- Dec 2008
- 212
05-18-2010 07:54 PMI've actually ONLY been in winning boats, Would love to have that other Yellow 34 Phantom that we had raced against in the past, That would be a good one to give Jim a run. I love that boat of his, handles ridiculous. I think the one thing i regret the most is losing to Bruce in Ocean City in his 30' phantom. Would love to have that one to do over. Chock it up to my inexperience i guess.
Apparently I still need to learn how to turn, Guess i was doing it wrong. ??
- 4,346
05-18-2010 08:37 PM
bilge,, you run the boat where you feel comfortable,,then step it up every lap..i,m sure youll be fine,,the Imco Phantom drives like a cadillac,,so the driving job is much easier and the ride is much safer,,,just being in a canopy gives you a lot more confidence,,good luck stop by any time ,,George Jr,
- Dec 2008
- 212
05-18-2010 09:17 PMYes there was a Yellow 34 That ran a few times, and was in Key West i believe. It used to say "Bluewater Realty" on the side. cool boat. Actually a 34 with a canopy would be the cats a$$, or cats Meow, or maybe even the Cats Pajamas.
- 4,346
05-18-2010 10:01 PM
Well how I like to make high speed turns. Well as soon as the flag is dropped, or the first post which ever comes first. I try to beat everyone by typing up to 90 wpm (words per minute). Than use the up arrow to simulate trim, space bar is throttle. Hit the shift to throttle down, 3 bumps on the right arrow for a right hand turn like for St Clair and Biloxi. Than brag on how fast I can type, and my awesome spelling ability. If I was able to break away and post first. I always give some advice on how I would do it in the real world.
05-18-2010 10:30 PM
Come on guys... It was a serious question and the guys who were kind enough to offer up some advice get banged on. What site is this again?
Were talking about a 30foot velocity in the 75mph bracket.
The tight turn in StClair is how tight? Radious wise 100yard U turn?tighter?
- 4,346
- Lake Travis Texas
- 6,844
05-18-2010 10:50 PMDD, the north turn may be tighter than that.
I think you should focus on knowing how tight you can turn at a given speed . Make sure you do not to cross or ride up on wakes while turning. Get your turn trim settings down pat.
You may find your first race a little overwhelming. Just take it all in and enjoy it. Just aim to finish without tearing anything up. That alone is an accomplishment. After you get one under your belt you will really have fun.Last edited by MOBILEMERCMAN; 05-18-2010 at 11:14 PM.
- Downtown Ruby, MI
- 213
