And many people probably join you in believing that. Problem is that racing orgs are supposed to have legitimate tech inspectors who do a credible job so no one has to guess what they believe.
Results 41 to 60 of 62
05-08-2014 07:56 AM
- 37,877
- 45
05-08-2014 08:25 PMI'm explaining poorly, but at least I'm used to it, (ask my wife).
With the RPM capped at 5450 for the APBA rules the prop slip would have to be 5% to hit 100 mph (1.5:1 gear), almost impossible in my belief for a Vee. A very fast Vee will be around 8% to 9% slip. That is with a surface pierce drive like a #6 or Indy, not a Bravo with a maximum height allowed of 1/2" below the running surface. However, with the 5800 RPM allowed by SBI Superboat Vee, 100 would calculate out to 12% slip on a 31" pitch prop. That is well within reason, so I would believe the boat could be SBI legal and run 100mph. The APBA record (Wil Smith) is 91+ on a 31" prop with a legal stock 525 Merc. That works out to 13% slip on the 5400 RPM the stock ECM allows.
Any better explanation?Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
- 37,877
- 45
05-08-2014 08:30 PMMy opinion is the inspectors do a pretty good job, but if you have enough money and you want to cheat badly enough, there isn't enough money to tear engines down all the time. The secret is to make the rules simple enough, and the punishments tough enough, to where there is no incentive to cheat. Both orgs are getting closer to making it simple, quick, and reasonable for the SVL's, Supercats, and Cat Outboards. Dataloggers are the key to ending cheating forever in my opinion. SBI just made them mandatory for SVL.
05-09-2014 06:56 AM
Your conclusion is probably right, the boat could be SBI legal and run 100mph. My question is the boat,IMO, normally runs at 6500 rpm (±200 rpm) so when does any team get to declare themselves "legal"? Isn't the org (whether APBA,SBI,OPA) the only party that can make that statement?
- 37,877
- 45
05-09-2014 08:13 AMThe short answer is to the question is yes. APBA has not even released their press release and I'm pretty sure that will clear up the issue. The only question is if there is any single engine Vee-bottom boat that has ever gone faster in an APBA time trial. The boat is not a legal boat in any APBA offshore class, and the event was a Special Records event, not an Offshore Records event. The rules are much stricter than Special Records events for Offshore Records events.
So, if there is a record granted for the 29, it will fit in this group somewhere: http://www.apba.org/node/5818
I don't know what it will be, or if there will even be a record granted. If so, it would probably be some new Special Events record like: Canopied/30' or Less/Single Engine Vee?Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
05-09-2014 10:00 AM
Problem with that type of classification is, unless the org certifying the Record releases the exact spec the boat ran (engine displacement, RPMs, weight, prop etc) then no one could effectively challenge it. You could even buy another 29 OL canopy race boat with race-prepped 525 and fail to match the speed.
05-09-2014 11:11 AM
Pretty simple explanation. They bought a record!!!
I am headed to the lake now, going to set a new record a certified by my cell phone gps. Ranger v-82 hybrid outboard carbed promax. or R82HCPM for short. Press release to follow.
05-09-2014 09:14 PM
APBA Official Press Release
Special Events Speed Records Established
Two APBA Special Events Straightaway Speed records were established in Washington, NC on April 29, 2014. Both records were set using OuterLimits boats powered by Mercury engines and Mercury stern drives. In the SV Single, Brian Forehand drove Michael Janssen’s OuterLimits SV-29 to an average speed of 100.836. In Unlimited Vee Bottom, Forehand drove Joe Sgro’s OuterLimits to an average speed of 180.464. Average speeds are established running in both directions over a one (1) kilometer surveyed course.
Congratulations to Forehand, Janseen, Sgro, Outlimits, and Mercury Marine!
- 37,877
- 45
05-09-2014 09:17 PMI'll get clarification from Mark Wheeler at APBA, but this appears to be a record for a 29' Outerlimits SV with a single engine.
05-09-2014 09:23 PM
The English guy that looks like Robert Plant (cant think of his name right now) that has the blue orange 29 ol with the ilmor.. he is definitly faster than doc... 29 ol single engine....
- 37,877
- 45
05-10-2014 11:20 PMI'm sure there are quite a few out there faster, but they weren't at the record trial.
According to APBA, the record set by the 29 OL is SV Single. SV is a copyright held by Outerlimits for several models of their Vee's. So, the special event speed SV Single record is held by a single engine Outerlimits SV and can only be broken by a single engine Outerlimits SV since they hold the copyright.Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
05-11-2014 11:49 AM
think his name is Peter something...
- 37,877
- 45
05-11-2014 11:29 PMI also think the one with the 600SC went 104 or so.....
But, no one else was invited to the record trial, so none showed up........Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
05-12-2014 11:30 PM
The 600 hp supercharged Mercury Racing engine was matched to a Bravo One XR drive with ½-inch spacers and 1.5:1 gear reduction. With that propulsion package turning a lab-finished 15 5/8 x 34-inch five-blade Maximus propeller, our test boat ran 101.3 mph at 5,350 rpm.
http://www.pokerrunsamerica.com/comp...-by-eric-colby
05-13-2014 11:25 PM
From APBA:
The speed runs were sanctioned as special events. This was done for two reasons. Either of these reasons would have made the speed runs special events (and not offshore).
1) The boats did not fit into an existing APBA class.
2) APBA never sanctions private speed runs for existing APBA classes. The speed runs at Washington were private. They were not open to all APBA members, and we would not have granted a record for an existing APBA class even if the boats fit into an existing APBA class.
- 37,877
- 45
05-14-2014 11:05 PMAPBA's explanation covers it pretty well I think.
- 37,877
- 45
05-15-2014 07:11 PMGetting bad advice is unfortunate, taking bad advice is a Serious matter!!
