Results 21 to 24 of 24
- 37,493
11-20-2012 09:04 AMNow there's a dilemma. The only thing that would make my mind up on that choice, do you want the cabin headroom because you plan to spend weekends on the boat, (and the occasional week). If not, the Apache has the "A" appeal, but will burn more fuel at the same speeds, and be a little bit slower at cruise and top end. But, all 41's were Kevlar and the layup's were tough as could be. It would out perform the BT in the really rough stuff. I would go with the BT, but everyone knows I'm prejudiced that way....
11-20-2012 10:42 AM
Another good person to ask would be Tony from Chicago. He owns the 41' called "Bad Medicine". I believe his boat meets the above description fairly closely. I am pretty sure that he is a member here, although I am not sure what his screen name is. He is friends with Mark (MrCig) and Ryan(Flatdeckcig). Maybe you could message them.
11-21-2012 08:15 AM
I'm not 100% sure on the drives on Tony's boat, and usually I'm up on these kinds of things! I am usually too busy checking out the awesome airbrushing on the hull! I think he's running 3As if I had to guess, and the motors are in the 700 hp range. He maxes out in the low 70s for sure.
