Thread: NOT cool(er)
Results 21 to 40 of 47
04-27-2010 12:56 PM
Actually...I might just have had my mind on other things...winterized right after Brian died. However...I am sure I did it the same way I always have.
And Joe...number 1...there's no Huffy's here...and number 2...I'm ALWAYS riding! Michelle's new road bike just got here...mmmm...carbon fiber...guess where I'll be tonight.
04-27-2010 01:13 PM
I think what happened is you were in the middle of winterizing, and that jerk phil called you and screwed you up. Thanks phil.
04-27-2010 03:36 PM
30 years of winterizing boats I always drain as much of the water as I can pull the thermostat out, hook up by bucket of antifreeze to the fresh water intake and start the motor and pump 5 gallons though. Knock on wood never a problem.
Lucky that is all that broke.
Mark
04-27-2010 04:07 PM
You guys using the pink RV stuff or the actual gycol antifreeze???
04-27-2010 04:09 PM
Pink stuff.
Well...now I know for sure what I'm going to do next year. I'm going to call Patti and tell her to have Mark come over and winterize my boat for me.
04-27-2010 09:15 PM
-50 pink stuff.
04-28-2010 06:49 AM
Maybe when he pulled his drain plugs on the blocks, some water came out, but then got plugged up with sand, and he still had water in there. Then he poured his a/f in, mixing with the water. Those coolers prob crack pretty easy. I bet the pink stuff when diluted dont work real well. If that was the case, lets be happy it was just a cooler that cracked!
Every year i gotta stick a small screwdriver or coat hanger up those block drains to clear them out, and bingo, out comes alot more water. At least when you run a/f thru the engine, any remaining water gets mixed up with the a/f. Pouring it in manually and letting it sit, just dont seem like its gonna mix up thru the entire water system. I like to see pink from the sea strainer to the tailpipe.
04-28-2010 06:57 AM
BTW, Mike, dont think im over analzying this topic on ya. Just like to learn how to keep this kind of stuff from happening. Doing the pour in method several years back, cost me a sea pump housing come spring.
04-28-2010 08:52 AM
I like to see pink to !!!!!!
04-28-2010 10:35 AM
Why do you think he leaves some bottles at the barn year round!!!!
04-28-2010 01:30 PM
Winterization...what's that?
1) Lower outboards to drain all water out.
2) Change lower unit gear lube.
3) Disconnect batteries.
4) Done
Nothing to it
