Results 21 to 40 of 93
    Miami
    I have a 35 motion with 575 and running Bravo 1 36's, will these work and whats the gain?
    Apr 2009
    julie how u doing baby girl,,,, can you please explain the gold coating ? i,v had a couple of people ask and i couldn,t answer,,properly
    Lake Nasty
    Quote Originally Posted by ThrottleUp Props View Post
    Yes Sir, I THANK YOU!!!!! Thats why the Bravo Props are $500.00, to comply with the Swap rules!
    They are my private collection, which is why I can sell them for $500.00 each!
    Julie
    Have a nice holiday.
    Did you tell me to subtract 2" of pitch when going from 4B to 5B?
    15.25" diameter will fit an XR -2" sportmaster correct?
    Can you give us the formula on dropping pitch for adding a blade?
    Cause somebody has to!
    St. Petersburg
    Quote Originally Posted by lowblue320 View Post
    Motions can perform well with Semi-cleaver Propellers. The owner of Motion recently called me a little and we discussed this. Your 36P props are not a real efficeint pitch, for Bravo I propeller series. I would think you would benefit greatly from semi-cleavers. But, before jumping in can you tell me the year of the hull and your performance data with the Bravo I props, please?
    Julie
    GO FAST or GO HOME!
    St. Petersburg
    Quote Originally Posted by imco offshore View Post
    Its all going so WELL, George! Thanks for asking.
    The Gold Coating on the props is a PVD coating that has titanium in it. This is what give it it's gorgeous color. PVD is short for "Particulate Vapor Deposition".
    Happy Holidays to both of you George!
    Julie
    GO FAST or GO HOME!
    St. Petersburg
    I wish you the very same, Fund!
    Happy Holidays!
    Julie
    GO FAST or GO HOME!
    St. Petersburg
    Yes, that is indeed the formula, if you are currently running Bravo 1 props. Bravo 1 props are one inch less than is stamped, on the propeller.
    When you add a blade you will reduce one inch of pitch to compensate for the increase drag of the additional blade.
    So... if you are running Bravo I props and want to add a blade you will reduce 2 inches of pitch.
    If you are running propellers other than Bravo 1 prop then simply reduce one inch of pitch when adding a blade.
    Julie
    GO FAST or GO HOME!
    Apr 2009
    is it bling or does it have a practical purpose? and what does it cost...
    St. Petersburg
    Here you go:
    The only exception to the rule, is if your running Bravo I props.
    Julie
    GO FAST or GO HOME!
    St. Petersburg
    Its got SERIOUS Bling factor !
    We are still testing the propellers to determine in a scientific manner the benefits.
    But, I can tell this to date. The PVD coating makes the propellers STRONGER! So, this of course would allow us to go thinner and with the PVD we can re-gain some of this strength back. This of course means greater Durability and Life Expectancy, for the propellers. Because we all know that thin is fast.....but we also know that thin propellers have a shorter life expectancy!
    The coating depends upon the propeller style. SM are an additional $1000.00 each for the PVD application.
    Thanks.
    Julie
    GO FAST or GO HOME!
    Bristol, RI/Wethersfield, CT
    PM sent instead.
    Julie
    P/M sent.
    It does it all....
    Attached Thumbnails Attached Thumbnails cumberlandrace%20007.jpg   cumberlandrace%20008.jpg   cumberlandrace%20011.jpg
    St. Petersburg
    Oh thank you Sean....those are my beauties!
    Julie
    GO FAST or GO HOME!
    St. Petersburg
    I have 6B props as well. I will post them in the "Showroom" in accordance to the swap shop rules. Thanks Fund.
    Julie
    GO FAST or GO HOME!
    St. Petersburg
    GO FAST or GO HOME!
    Charter Member / Competitor
    New Port Richey
    Julie call me on 27 28 30
    Thanks
    Steve
    St. Petersburg
    Thank you OTF!
    Julie
    GO FAST or GO HOME!
