Thread: How I spent my weekend
Results 21 to 40 of 44
10-14-2010 02:03 PMAllergic to Nonsense
10-15-2010 06:14 PM
10-18-2010 02:10 AM
How is Mr. G? He might be right you cannot knock it until you try it.
I really like the wing it is all about what is missing these days in racing.
Good luck with her.
pat W
Rik don't even think about it..... you are not allowed to ride along. I was thinking the same thing,... he needs a counter ballance and another beanie. What rotation is on the beanie?Unique Innovative Drivetrain Solutions
10-18-2010 08:43 AM
Jerry is doing fine....... and looked great at OFF.
I spoke to just about everybody who ever flew a wing... (most of them were at OFF).....and not one of them ever spun the props inboard. The hull wants stern lift...(It is a hydro not a cat and many don't relate to the significant differences between the two designs)..... I am vehemently opposed to "spinning in" on almost every other hull because I believe firmly that this aggravates the tendency to lean out and barrel roll in turns. As currently set up, she slides perfectly when turning due to the short fins that we installed at the back of the forward steps balanced against the rotation of the LU's. We are moving some weight around and increasing the depth on the aileron to try and calm her down, before I play with any rotational changes.
Rik...you are welcome in the passenger seat at any time....but , so far, nobody has actually volunteered for that opportunity......
RichAllergic to Nonsense
10-18-2010 08:56 AM
Real cool seeing that video, reminds me of my younger days, hanging out with the Merten's and watching their dad test stuff
Run until it sounds expensive
10-18-2010 11:50 AM
Jerry ran those skid fins on the 46 SKater Alcone..... I always liked a pivot point.
How much rocker is in the bottom?
Where does the cg end up with you in it?
Where do you run the trim?
If you put Rik (dead weight) in the Starboard side it might push the cg enough to stop the porpoising and add a little stability for high speed.
pat W
10-18-2010 12:42 PM
No rocker....but the forward step is 4-5 inches deep (tapered bottom)...
C/G is basically in the middle of the fuel tanks.. (midway from cockpit to transom) and the boat does not rotate for nor aft when airborne..... good balance. However I am running a 60 lb sand bag in the passenger cockpit so we are moving both batteries to that side and forward to the back of the step (from parallel to the back of the wing section currently)
I have run the trim everywhere from negative 7 degrees to almost level, but not in uniform conditions...I need more testing for both trim and prop depth (adjustable on these motors from 3" under to 4.5" under)....... to find the "sweet spot". Boat should run best at lowest engine height with about 5 degrees negative trim according to Ken Kitson....(World Champion Wing driver from back in the day)...... Of course he never ran high rake props or 4 blades either.
The 20 footer is definitely more prone to loping than the smaller 18 but it needs to come out of that lope by 70 mph or so and fly level..... Right now it is carrying the lope well above that speed. Perfect flight angle is running on the prop shafts aft (bottom 3-4 inches above the water) and the forward sponsons running at the same height or slightly lower ....totally airborne.Allergic to Nonsense
10-18-2010 02:05 PM
With the higher rake it should need less trim. How about 5 or 6 blade for a little more transom lift?
I think Rik weighs 60 lbs wet...
What was the weight difference on the original engines to the current ones?
Do you have jack plates on there?
pat W
Sorry for all the questions just very interesting.Unique Innovative Drivetrain Solutions
10-18-2010 03:08 PM
You need to do a photo "expose" and a write up on the wing....
To turn it do you back off let it settle the sponson(s)?
10-18-2010 05:54 PM
You have to set the sponsons before turning......
Before the fins....when you turned the wheel at speed...the bow turned but the boat kept going in the direction the engines were pointed.......... now it takes a set at about 75 to 80 and carves a turn beautifully. I could turn tighter/faster with a longer fin like the hydros use today but that would require a lot of reinforcement and for Vintage use is totally unneccessary.Allergic to Nonsense
10-19-2010 11:59 AM
Are you running the #4 SSM gearcases or stock type?
It is nice they put the vertical trim in the mid section.
After you cut the power does it float for a bit before it settles going into the turn?
10-19-2010 06:19 PM
I remember when Mercury had brakes on their boats
10-19-2010 11:39 PM
I did some extensive work on those funny little drives in the recent past..... When you want to get more out of her let me know.
10-20-2010 03:29 PM
Just worked over seas with a few teams.
You can never have enough power....
