This from Bladder Man?
No. The oxygen is dangerous... using straight Hydrogen.
I think that my buddy's shop will grind it, (emptied and watered) as I think that the noise in my residential hood would be a little much. I don't want them to start calling the city. They will ticket me for parking in my yard.
Then I will drag it back and continue.
Thread: Funds Brave restore thread
Results 261 to 280 of 840
07-01-2009 06:55 AMWarning: This post may contain language unsuitable for minors or math not suitable for liberal-arts majors.
- 37,872
- 45
- 3,107
07-01-2009 09:17 AMfund, I did something similar with my Panther some years ago (circa 98')...
The tank wasn't leaking but the top was bowed up and some of the baffles were dislodged.
It was a 150 gallon tank and I replaced it with something in the 130-140 range. My fabricator basically cut 4 inches off the rear of the new tank so we could get it back into place due to the bulkheads and having to drop the tank one end at a time. Luckilly I didn't have to make the tank more narrow.
also, I had my fabricator build the tank with a heavier gauge aluminum and also had it epoxy coated.
Frank
07-01-2009 04:03 PM
I could pm her Brandon and ask. I have her pm address.
07-01-2009 09:34 PM
Plus, his expression sums up what life has been like lately.
- 37,872
- 45
07-01-2009 09:47 PM
28.5 inches wide x 77.5 inches long x 15.25* inches deep.
*at the place I dipped the tank (2/3 way back at sending unit) it could be bowed downward due to weight of gas in tank. Let's use 15.
28.5 x 77.5 x 15 = 33,131.25
cubic foot = 1728 inches
33,131.25 by 1728 = 19.17317708 cubic feet
7.48051948 US Gal per cubic foot (at a given temp)
19.17317708 x 7.48051948 = 143.4253246 gallons
So, let's assume that the middle is bowed but the ends are not:
28.5 x 77.5 x 15.175 = 33,517.78125 by 1728 = 19.39686414 x 7.48051948 = 145.098562
Let's call it a 145 gallon tank.
More or less.Warning: This post may contain language unsuitable for minors or math not suitable for liberal-arts majors.
- 37,872
- 45
07-01-2009 10:26 PMWarning: This post may contain language unsuitable for minors or math not suitable for liberal-arts majors.
07-01-2009 10:40 PM
Baffle panels could take up a little volume.
Let's call it 75.
And the hole for the tank cover will allow a 130-135 gallon tank.Warning: This post may contain language unsuitable for minors or math not suitable for liberal-arts majors.
07-02-2009 06:10 AMWarning: This post may contain language unsuitable for minors or math not suitable for liberal-arts majors.
07-02-2009 08:51 AM
Are you sure the tank is leaking John??? sorry to hear! I had it checked when it was surveyed, no problems then? It seems like a never ending project!!
07-02-2009 09:26 AM
I can't imagine where 4 ounces a day of gas is coming from, other than the tank. The survey said that it was visually inspected, was "sound as sighted" but they recommended having it pressure checked. The survey gave the capacity as "135 gallons as reported" which just means that's what the owner told him. I found it to be 145 when measured and converted to volume.
Having visually inspected the fittings on top of the tank, the lines, and the foam all around the tank, I would say that there has been a great deal of water intrusion from above, the foam has shrunk away from the stringers quite a bit. My guess is a leaking bottom where water sat or a cracked weld in a corner.Warning: This post may contain language unsuitable for minors or math not suitable for liberal-arts majors.
