My mind of wife..... just sayin.....
Printable View
Your wife is a great lady!!
Updates please
Your welcome! Good luck on the HTM. My current project is going slowly right now but its worth it. Bravo to arneson conversion (the imco SC's could not handle the power!).
Sterling i have a glove box tub for you from XT that i need to get shipped to you can you email me your name address and phone number to huntinfrek@aol.com thanks Ed
I,m back on track ,and would like to say thanks to all you people that were following this thread .
The reason I stopped working for a while is that I wanted to build my blower engine back into the HTM ,and also changed the drive from a XR to a Bmax ,the blower engine broke last year after 10 hours run time due to a broken pushrod guide plate ..the rocker started to turn,and pushed the retainer ,this cause the valve locks to let go of the valve stem ,and the valve dropped down on the piston ,this all happened in Italy on my holid..ay ...mm bad luck ...so we build up the engine again with a new set guide plates ,new valve ,rebuild head with a cracked valve guide ,piston wasn,t too bad hurt ,only a few scratches cause it happened at idling .
Ok ,so we put it back in the water ,and run it for half hour or so ,when I noticed a strange sound and power loss ,back home when we removed the valve cover we found another broken pushrod guide plate ,this time it was the other cilinder head that had a cracked valve guide ,bent valve ,etc etc ..needless to say I am very dissapointed in Manley pushrod guide plates,we took them all off and looked at them under a microscope ,and found haircracks in almost all the guideplates.
So this was a little time/money consuming ,and I,m back on track with finishing the Baja .
A.J
Glad to hear things are rolling again, good luck
So the water tank is in ,as is the holding tank ,and water press pump ,boiler ,fridge ,microwave,victron combi unit as a battary charger ,and inverter,powersteering pump is full with ATF and pressurized with a drilling machine to see if all is leakfree (and off course it steered in the wrong direction wich causes a exxon valdez oil disaster under the dash) but its all cleaned and working great.
My wife finshed the rear seat ,and all the upholstery in the front under the deck because this boat was a poker run edition ,there was nothing in front ,so we build a galley ,head ,etc.
A.J
THanks for the updates! Looking REALLY good.
keep us posted
congrats on the progress
That upholstery color looks really sweet.
Thanks guys ,we have both the side panels ready ,and some cushions in the front ,also the left bolster is mounted ,speakers are also mounted in the side panels,bolsters are wired and working .
Will post some pics soon .
A.J
So is the HTM completely done?
Yes it is ... I had to bring the blower engine to my engine builder ,they are going to build it up, I just bought a Mercruiser 540 Bulldog and put it in the HTM ,it runs good now ,just around 78-79 MPH ,trouble free and no blower surge ,I needed to make another engine hatch because the Bulldog fits under the hatch ,so no blower scoop needed, so I threw away that hatch and made a new one .
A.J
