Amzoil Marine Gear Lube!
Printable View
I'm running mobil 1 gear lube. Costs the same and mercs conventional hp gear lube. In amsoils tests best lubes were:
1-amsoil
2-mobil 1
3-gm synthetic
http://www.amsoil.com/products/gearl...hitePaper.aspx
lots of interesting info. I chose mobil because it is reasonable $ and easy to find. Plus I already had a few cases!
Whats the difference between Universal Synthetic Marine Gear Lube and Severe Gear 75W-90? Prices aren't bad, if only you could get it at walmart!
I don't know what the real difference is but I'm using the severe gear as that was what was recomended to me by max worx,Smitty
I am afraid to use Mobil1 in gearcases. Mobil1 make no reference to marine use in their product description. A good marine gearlube has things to tolerate
moisture and water intrusion.
I use Mobil1 engine oil religiously. I use Merc or Amsoil gearlube only. Customers choice.
I don't know about the gear lube, but I remember one of the benefits of the motor oil was a good tolerance to water intrusion.
The difference is that the Marine Gear Lube has Less Sulphur in it, which is an anti wear additive. Excess sulphur can have an adverse effect on soft yellow metals that are sometimes used in Marine Gear Cases. The Marine Gear Lube is a GL-4 and the Severe Gear is a GL-5. GL-4 has less Sulphur.
Thanks 07.
I can’t imagine running anything non synthetic ever…
Now when it comes to the Lucas stuff, anything I’ve ever used from them has always worked flawlessly. With that being said as said before I usually try to avoid anything that is sticky inside any type of engine or gear case. It robs power, and can hold the grime and debris next to the parts you’re trying to protect.
In the race engines I deal with the oil is so thin it’s not even funny, nothing sticky EVER… Heck we’ve backed up to 2WT oils now a days:biggrinjester:
Amsoil?
My U.J.'s run in a bath of oil. Some of the Arnesons use ordinary ATF fluid and I have a customer that swore by Amsoil b/c it lowered the temps on his Bravos.
After 250 hrs with 850 hp blower motors I went through the drives to check things out. (Boat is a 382 Formula and it is loaded = heavy)
U.J. bearings with the ATF fluid looked better than the ones that ran in Amsoil. Both were still good, but the customer used ordinary no name brand ATF fluid in one drive and the Amsoil in the other drive.
As for an Arneson, my belief is .... Oil is Oil. I tell customers to use Merc as they either have it or can get it and it separates the water out if they loose a seal.
I prefer the Mobil 1 Gear oil simply due to nothing more than availability. There is a Grainger in most any town in the US. They carry Mobil 1 Gear oil so it makes acquiring it very easy for anyone.
I get 8-12 thousand hours before rebuilds on drives using nothing more than a standard Mineral 80-90 wt oil also. So go figure.
As far as Bravo's ? I have no experience on what works.
Sorry if I sound stupid but what are U.J.'s. Also, Arnesons get thousands of hours before rebuilds, or was that a typo??
I hate to say it because I'm dependent on the Merc stuff, but the reason why the fluid in the Bravo is so important is because they were under engineered from the get go(1987), and every little thing helps and is needed to get them to survive the HP people(including Merc) are putting to them. I use to run TRS's, and those drives were over engineered for there applications, and if Merc would have thrown some upgrades at them way back when, the high performance boater would be better off. The NXT 1 drive has alot of similarities to the now old and outdated TRS, but costs what to buy(30,000+). Merc could of easily redesigned the drawbacks of the TRS(lower units) and had a great drive that is affordable to the public and profitable to Merc. I know Merc makes some great stuff, and like any company, they are in business to make money. But because they have a monopoly on the market, they charge more than a premium on all there products. Of course this is just my opinion, and sorry for the rant, but I added up what its going to cost to go thru my drives for next season, and its a little disturbing...
LE
U.J. is a Universal Joint
No typo, the typical fishing boat up in Alaska gets roughly 8,000 to 12,000 hours on them before they take the drives off the boat and change bearings and seals. Some get more. The patrol boats are the same way.
They use any oil they can get their hands on, probably whale fat for all I know. We recommend just generic 80-90 wt gear oil like what is used in your car transmission or rear diff.
U-joints, that makes too much sense now that I think about it. Obviously the Arneson is an over engineered piece.
LE
FWIW, I just picked up a modified rear axle for my GT500 which included new gears. The shop specializes in ultra custom 9 inch style rear ends taking thousands of horses (race applications)
The Warranty was only good If I continued to run TORCO GL-6 gear oil. According to this shop, most all the big name drag racers are running this now.
Torco is Dino oil BTW.
In case anyone is interested;
http://www.torcousa.com/technology/060912113038RGO.pdf
