Has anyone installed an inhull transducer in the engine compartment of a stepped hull formula.I have a 2004 382 and I would like to mount the transducer in the engine compartment.
Printable View
We installed one today in a 2000 312,the factory transducer was in a hole cut thru the liner, we dug it out and glued the new transducer there.
So you dont think the air from the step hull will bother the reading?
I don't think you have a liner, Rob.
...smooth-off a spot, and glue it down with either resin or 4200/5200. Make sure to not have any air-voids underneath the ducer. Then go looking for some thin water to check it out. :)
We use the epoxy that Lowrance or Humminbird supplies,resin is also good. Just don't use silicone sealer,it kills the signal for some reason.
thats great to know Robert, I was dreading digging out the other puck. now that I know i can do it this way I will do it further back and under an engine to stop the wire from getting stepped on.
I have a 2006 292 which is a twin stepped hull like your 382. The factory depth finder didn't work very well and I replaced the thru hull transducer with one compatible with the SC5000 smartcraft display. The factory tranducer is located under the hinged step entering the cuddy cabin and this is where I installed the new one. I researched this and you MUST install the transducer forward the the steps in the hull or you will not get a good reading when on plane. The factory transducer was smaller in diameter than the new one I was installing. There IS a liner, so I had an experienced shop with the right tools enlarge the hole in the liner. The new transducer has a housing that I siliconed to the hull and filled with mineral oil. The transducer attaches to the housing and is sealed with an o-ring. The signal shoots through the mineral oil and hull. Works GREAT, even running 70 mph!:) I would not install your transducer in the engine compartment unless you don't care to see the depth while underway.
Yup, no problem mounting near the transom for a non-stepped hull. The issue with steps is they aerate the water and this causes interference with the sonar. The transducer needs a solid path when sending the sound waves to the bottom and back. That's why any gaps between a liner and hull or air bubbles in the epoxy can cause problems too.
