AC delco plugs, two differant types work the same
Ac Delco 41-933 Platium
AC Delco R 43TS
I have to two L29 454s year 1998 and the other 2000 year made. Both have the same heads and block casting #s and yes they are the peanut heads.
Both head sets have at least 11/16 of threads in the plug hole that matches the AC 41-933 length of threads, I have two of the same motors with differant plugs as listed above. The R 43TS has about 3/8 of threads.
Both motors run awesome and have no differance so far in performance.
I read both sets of plugs to freak out with perfect burn on both engines.
I am confused now, which set should I use for both engines
The 41-933 cost a ton of $, isn't there a standard plug that has a long reach on it but same heat setting as the R-43TS with 11/16 of threads.
Thanks for your time on this.:seeya:
Kurt
