Most likely, no. Sounds like you have high drives, wrong props, no flare ring or not using the proper technique for getting on plane.
Toe in/out is something to experiment with. Different settings will give you better speed, acceleration, handling, etc. It also makes a difference if it's a cat, V bottom, drive height, turn in or out, etc.
It's best to experiment by making 1/8" changes until you find what works best.
