rebuild the dash pad????
bajabob 718
Member
ok i made a new engine hatch .last one lasted 10years cost $450 to make and a few :cheers2:. nowthe dash is roted i got to do that now it suck the water gets behind it . i need some ideas on this one
The viynl looks decent, the easy way would be to get some ply do a resin coat and put it back together. But I am not one to talk to for the easy way. :D
Do you have a picture from before you stripped the dash so we know what look you're trying to acheive?
here is one not that good .i try to put it back on then you can get a better look
jeff i am doing that to the engine hatch now. i drill it for the bolts and sanded it down today . then next week i am bring it to get cover by jeff he did a lot of outerlimit boat . .so now i got to do somthing with the dash . ya the viynl is bad it looks good in the picture
here the engine hatch on friday the dash shold be done you can see i made it out of plywood seal it and black paint . it will be cover with the red mat.
ok the dash is done the shifter install:cheers2:jeff did a great jop and it didnt hurt the bank$$:cheers2:
i did it i took a stop sign bend it and put that carbin paper on. .there a guy selling a dash with new gauges for 550done.i got new gauges the only thinig i should have done is the speedo is 80mph and i go pass that now i need a 100mph :cheers2:
