Boatally Insane
I have two different sets of pistons and am trying to decide which ones to use in my low budget build..
I have a Gen IV block with a forged crank and rods. The crank, rods, and pistons look like new, but the block's cooling passages have a LOT of rust and the cylinder walls need some attention. :ack2:
The pistons have 6262976 stamped on the top of them.
I've found a LOT of info on these.
From Dennis Moore's book.
I also have a Gen VI block that appears to have been a fairly fresh rebuild. The pistons and cylinder walls look like new but it has a cast crank / rods AND a spun a rod bearing. :willy_nilly:
The pistons have 6262977 stamped on the top.
ALL I've found on these is from Dennis Moore's book...
Any ideas?
Also, any idea why the speed pro L2399F isn't listed for use in a Gen VI block?
I'd like to use the Gen IV forged rotating assembly and my Gen VI block (with a rear seal adapter of course) .....but which pistons...?..
Thanks,
Doug
They also cross to a speed pro L2399FPiston Assembly. std. 1971 454-cid
RPO LS6 Forged Aluminum w/9.0:1 compression
Pressed-pin design (ident. 3994031, 3999295, 6262972
or 6269362-3)
I can't seem to find ANY other reference to these pistons....anywhere...Piston Assembly. std. High-limit
1971 454-cid RPO LS6 Forged Aluminum w/9.0:1
compression. Pressed-pin design (ident. 3994032
6262973 or 6269364)
Any ideas?
Thanks,
Doug
