The pic on the left is -6 JIC (AN) as is the one on the right. The one on the left is your typical Aeroquip/Earl's 300 psi fitting. The one on the right is 4000psi hydraulic.
They screw together.
They don't leak.
And your fuel pressure regulator is going to read 7psi when you set it up. But the internal diameter on the left is 3/8" and the one on the right is 1/4"
The area of 3/8" is .110" and the area in 1/4' is .049. Less than half.
So at 5500 rpm, your big inch motor is going to be starved for fuel. And melt down.
They don't leak.
